Cisco Switch 9300 VRF
vondoom2
Good afternoon,
I am currently trying to understand the nuances of making loopback testing for a Cisco 9300 Switch coming from a Cisco 3850.  Below I have listed the series on commands used when performing a loopback test on a 3850 Switch.  Would someone be able to help me devise how this would translate to working in the newer 9300 Switch please?
Switch#: conf t
Switch#(config)#: no ip domain-lookup
Switch(config)#: vrf definition BLUE
Switch(config)#: address-family ipv4
Switch(config)#: exit-address-family
Switch#: end
Switch#: conf t
Switch(config)#: int Gi1/0/13
Switch(config-if)#: no switchport
Switch(config-if)#: no vrf forwarding BLUE
Switch(config-if)#: speed 100
Switch(config-if)#: ip address 10.10.10.1 255.255.255.0
Switch(config-if)#: no shut
Switch(config-if)#: exit
Switch(config)#: int Gi1/0/48
Switch(config-if)#: vrf forwarding BLUE
Switch(config-if)#: ip address 10.10.10.2 255.255.255.0
Switch(config-if)#: end
Switch#: ping 10.10.10.2 source Gi1/0/13
2 Accepted Solutions
show version
and License you have , you need network advantage to support VRF
BB
9 Replies 9
Switch#: conf t
Switch(config)#: vrf definition BLUE<<- add RD to VRF with command vrf rd 1:100
Switch#: end
Switch#: conf t
Switch#: ping vrf blue 10.10.10.2 source Gi1/0/13
When I tried to enter in your suggestion the switch says that RD is an invalid input.
Thank you very much for all your help.  This chart was very helpful and using the link you provided and the
show version
command I do see that this version is listed as a Network Essentials and not an Advantage.  Thanks so much again for your help.
balaji.bandi
what are you trying to do in terms of VRF config, nothing changed from 3850 to 9300
is the config provider 2
switch config
or the only one switch?  you also need to VRF routing GRT table.
 ping  vrf 10.10.10.2
BB
Only the one switch.  For testing purposes we have loopback cables attached to the back of our test assemblies and ping from port to port to confirm the test cable and wiring integrity is adequate and correct.  When I try using the commands listed above, the
vrf definition BLUE
is not accepted.  It says "Feature is not supported" on the 9300 Switch.
show version
BB
Thank you very much for your response.  Upon looking into the version it is indeed setup as a Network Essential and not Network Advantage.  I will have to see about being able to change that.
you cam enable the feature and get License soon (but you can test)
license boot level network-advantage
BB
