BGP Default Route & MPLS ?
I have the following situation and looking for an answer, I have 3 routers connected as following
R1 AS 64600 <---> R2 AS 2856 VRF1(MPLS) <------> R3 AS 64620
the 3 routers are connected via BGP mpls, R1 is redistributing default route into BGP from OSPF but R3 is not seeing that default route, any idea's why R3 is not seeing the default route ?
davidsudjiman
Samir,
Check whether AS64600 peering with AS2856.
Check whether AS65600 advertised out the routes to AS2856.
Check whether AS2856 peering with with AS 64620.
Check whether AS2856 advertised out the routes of AS64600 to AS64620.
Check whether AS64620 receives routes from AS2856 and 64600.
David Sudjiman
