STATIC IP ADDRESS BINDING USING CISCO 1841 ROUTERS
sathya256
Dear Team
I have configured DHCP in Cisco 1841 router , But the DHCP is working fine .Kindly help me to configure Static binding of IP address in DHCP .he
Today 30-07-2013  I have tested to DHCP using IP mapping with Mac address as per discussion . But finally the static mapping not working . Here with attached the Command list . Please kindly help me to resolve this .
Dennis Mink
what have you tried so far to get it to work?   can you send config.
thanks
Please remember to rate useful posts, by clicking on the stars below.
hi ,
after configuring DHCP and all for client bindin you can use belwo command to map it.
ip dhcp pool name-pool-static
host 192.168.0.253 255.255.255.0
client-identifier 0100.xxxx.xxxx.xx (MAC Address of the device)
Gajendra
cadet alain
to configure static mappings:
1) look at your dynamic bindings with sh ip dhcp binding x.x.x.x to see what client-identifier the client is using
2) delete the corresponding bindings with clear ip dhcp binding x.x.x.x
3) create your host pools like this:
  ip dhcp pool host_pool
  host x.x.x.x  y.y.y.y  where y.y.y.y is the subnet mask
  client-identifier 01xx.xxxx.xxxx.xx
   or
hardware-address xxxx.xxxx.xxxx  <<< MAC address
Regards.
Alain
All I'm trying to accomplish is this typing it in the console, but what script it takes to do this!?:
INTERNET---[CABLEMODEM]-d-[Fa0/0[Cisco1841]Fa0/1]-s-(192.168.0.1_.252 (1-host))---[PC]
s=static; d=dynamic
I've been trying to do this since the Cisco 2501; please... trying very hard not to rant.
