bgp fast-external-fallover - enabled or disabled?
richardwiseman
bgp fast-external-fallover is supposed to be enabled on Cisco IOS by default.
If in the config you do not see "bgp fast-external-fallover" under router bgp 12345 does that mean it is enabled?
Router is running12.4(12)
Jon Marshall
Richard
Yes it is enabled by default and hence doesn't appear in config. Only time you would need to enable it is if it has already been disabled ie.
router bgp 65121
no bgp fast-external-failover
Jon
Jon Marshall
Richard
router bgp 65121
Jon
many thanks
