BGP inbound and outbound traffic 2 ISPs
arturmelyan
We have Single Multihomed BGP design with 2 Enterprise routers. See attachment.
Enterprise routers are configured as iBGP neighbors.
Receiving Full routes and Default route from both ISPs.
Advertising one /24 block.
I am keen in getting implementation as follows:
1. All outbound traffic should go across 1st ISP. (Actually not all, traffic destined for 2nd ISP clients goes over 2nd ISP by applying route map with match clause and setting local pref. So in this case the rest internet traffic which is not destined for both ISP1 and ISP2 clients).
2. All inbound traffic should come from 2nd ISP.
3. In case of fail one of ISPs, another one must assume handling of Inbound and Outbound traffic.
4. In case of fail of monitored host in the internet (for instance ping to 8.8.8.8), Outbound traffic should start to go through 2nd ISP.
Is this scenario possible to put in action without involving of technical guys from ISPs in order they to not make some configurations at their side?
If so, please guide me how to make it works.
Thank you.
15 Replies 15
you need a combination of local preference, as path prepending, and IP SLA. Do you already have the two routers configured, and if so, can you post the configs ?
Hi Georg,
Thanks for your response.
I haven't configured them both yet and I am still working on it.
Currently only one router is operating in the production and have BGP configured for 2 ISPs.
So by adding the 2nd router in the production network I would like to achieve the scenario described in the above message.
Here is the configuration I have so far only on the 2nd router which should be connected to the 2nd ISP.
ip as-path access-list 1 permit ^222$
ip prefix-list ANNOUNCE
seq 5 permit 10.99.99.0/24
route-map ONLY-ISP2-NETS-OUT permit 10
match as-path 1
set local-preference 150
router bgp 111
neighbor 10.222.222.222 remote-as 222
neighbor 10.222.222.222 update-source lo1
neighbor 10.222.222.222 ebgp-multihop 2
neighbor 10.1.1.1 remote-as 111
neighbor 10.1.1.1 update-source lo2
neighbor 10.1.1.1 next-hop-self
address-family ipv4
neighbor 10.222.222.222 activate
neighbor 10.222.222.222 prefix-list ANNOUNCE out
neighbor 10.1.1.1 activate
neighbor 10.1.1.1 route-map ONLY-ISP2-NETS-OUT out
have a look at the link below (scroll down to BGP topology 6), it has a couple of dual BGP sample configurations. You don't necessarily need the IP SLA, as the failover should be automatic...
https://showipbgp.com/sample-cisco-bgp-configuration-by-topology/
Thanks for sharing such a nice examples.
However, I have only one /24 block and based on the configuration of topology 6-1-2. Cisco dual BGP with AS prepend-iBGP (Load-sharing)
it will not work for me.
Any suggestion would be greatly appreciated.
I will lab this up and get back with you...
I have labbed this up, this is what I have come up with. Basically, on the E1 router you set the local preference and the as path prepend, and on the E2 router, an IP SLA triggers an EEM script that changes the local preference in case the SLA fails. All IP addressing is obviously arbitrary...
hostname E1
interface Loopback1
ip address 100.100.100.100 255.255.255.255
interface GigabitEthernet0/0
description Link to E2
ip address 192.168.1.1 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
description Link to ISP_1
ip address 1.1.1.1 255.255.255.252
duplex auto
speed auto
media-type rj45
router bgp 1
bgp router-id 100.100.100.100
bgp log-neighbor-changes
neighbor 1.1.1.2 remote-as 2
neighbor 1.1.1.2 route-map LOCAL_PREFERENCE_150 in
neighbor 1.1.1.2 route-map AS_PATH_PREPEND out
neighbor 192.168.1.2 remote-as 1
neighbor 192.168.1.2 next-hop-self
route-map AS_PATH_PREPEND permit 10
set as-path prepend 5
route-map LOCAL_PREFERENCE_150 permit 10
hostname E2
track 1 ip sla 1 reachability
interface Loopback2
ip address 200.200.200.200 255.255.255.255
description Link to E1
ip address 192.168.1.2 255.255.255.252
duplex auto
speed auto
description Link to ISP_2
ip address 2.2.2.1 255.255.255.252
duplex auto
speed auto
media-type rj45
router bgp 1
bgp router-id 200.200.200.200
neighbor 2.2.2.2 remote-as 3
neighbor 192.168.1.1 remote-as 1
neighbor 192.168.1.1 next-hop-self
ip sla 1
icmp-echo 8.8.8.8 source-interface GigabitEthernet0/0
frequency 5
ip sla schedule 1 start-time now life forever
event manager applet ISP_1_DOWN
event track 1 state down
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "route-map LOCAL_PREFERENCE_200 permit 10"
action 4.0 cli command "set local-preference 200"
action 5.0 cli command "exit"
action 6.0 cli command "router bgp 1"
action 7.0 cli command "neighbor 2.2.2.2 route-map LOCAL_PREFERENCE_200 in"
action 8.0 cli command "end"
event manager applet ISP_1_UP
event track 1 state up
action 3.0 cli command "no route-map LOCAL_PREFERENCE_200 permit 10"
action 4.0 cli command "exit"
action 5.0 cli command "router bgp 1"
action 6.0 cli command "no neighbor 2.2.2.2 route-map LOCAL_PREFERENCE_200 in"
action 7.0 cli command "end"
Hi Georg,
Thank You once again for your assistance.
Let me comment my understanding regarding your configs:
E1<->ISP1:
1. neighbor 1.1.1.2 route-map LOCAL_PREFERENCE_150 in - makes Outgoing route preferable as compared to E2<->ISP2
So, the path of packet is become: E1-ISP1 or E2-E1-ISP1
2. neighbor 1.1.1.2 route-map AS_PATH_PREPEND out - makes Inbound route preferable ISP2-R2
Please correct me if I am wrong.
E2<->ISP2:
Here, everything is clear.
Only one thing connected with event manager applet - Don't we need clear ip bgp command inside it as well?
Hello
I would say with your current setup you wouldn't require tracking with ip sla if any isp has a failure upstream then those routes wouldn't be advertised towards your rtrs as such the less preferable prefix in the bgp rip would would take precedence in the global route table and resiliency would be provided based in the path attributes you have applied be it weight-local preference as prepending etc..
Kind Regards
Paul
Hello
Looking at your posted configuration the LP route map is applied in the wrong direction, it should be ingress on received routes and egress on advertised routes, However as this is currently for a single bgp rtr  peering towards two ips ebgp rtr you would set a weight path attribute for a preferred received prefixes again ingress.
As/when you have dual ibgp rtrs then weight pa would'nt be applicable, you would need to incorporate local preference again using the same logic.
Lastly you also need to make sure your enterprise rtr do not become a transit path for either isp.
Example1: <--- Single rtr with two ISP ebgp peers
Router1 to  isp 1<-->  isp2
ip as-path acess-list 10 permit ^$  < advertise only local routes to isp to negate transit routing
route-map ISP1-Weight permit 10
set weight 40000  < set default weight on all ingress routes
access-list 1 permit 10.99.99.0 0.0.0.255
route-map ISP2-Weight permit 10
match ip address 1
set weight 50000  < set higher weight on specific ingress routes
route-map ISP2-Weight permit 99
set weight 30000 < set default weight on all ingress routes
route-map ASPREPEND permit 10
set as-path prepend 111 111 111  < advertise rtr as a least proffered path to ISP's
router bgp 111
neighbor 10.222.222.221 route-map ASPREPEND out
neighbor 10.222.222.221 route-map ISP1-Weight in
neighbor 10.222.222.221 filter-list 10 out
neighbor 10.222.222.222 route-map ISP2-Weight in
neighbor 10.222.222.222 filter-list 10 out
Example2: <---Dual ibgp rtrs with two ISP ebgp peers
Router
1 <->Isp1
router bgp 111
bgp default local-preference 40000  <---set higher default LP on all ingress routes
neighbor 10.1.12.2 next-hop-self <---set next hop of ibgp peer
neighbor 10.222.222.221 filter-list 10 out < advertise only local routes to isp to negate transit routing
Router2 - Isp2
route-map LP permit 10
match ip address 1
set local-preference 50000
route-map LP permit 99
router bgp 111
bgp default local-preference 30000 <---set lower LP on all ingress routes
neighbor 10.1.12.1 next-hop-self<---set next hop of ibgp peer
neighbor 10.222.222.222 route-map LP in  <---set higher LP on specific ingress routes
neighbor 10.222.222.222 filter-list 10 out < advertise only local routes to isp to negate transit routing
Kind Regards
Paul
Hello Paul,
Thank you so much for your response.
I'll start by answering to your last 2 questions.
1. Its only your enterprise rtrs that IBGP peers to each other correct and the ISP peering is EBGP? - Correct.
2. Also are the isps in the same or different ASN? - In the different ASN
Regarding the LP route map is applied in the wrong direction, it should be ingress on received routes and egress on advertised routes - Exactly, I wrote it incorrect.  I just was confused a bit about Ingress and Egress concepts. Now it is everything clear.
So, now I am solely interested in Dual rtrs with 2 ISPs.
As for Lastly you also need to make sure your enterprise rtr do not become a transit path for either isp - Doesn't below prefix-list on both enterprise routers solve this problem?
Thank you for support.
Hello
ip prefix-list AN
NOUNCE
Apologies I was looking at this ONLY-ISP2-NETS-OUT so YES the current prefix-list would only advertised that subnet
but to save amending a prefix list you could use an as-path filter on your local asn and that would do the trick with less future administration.
Kind Regards
Paul
to safe amending a prefix list you could use an as path filter on your local asn and that would do the trick with less administration - I will keep it in mind, thank you.
ONLY-ISP2-NETS-OUT out - This route map is needed for directing Outgoing traffic through ISP2 (E2-ISP2 or E1-E2-IPS2) which is destined for ISP2 clients only. And certainly, the direction should be changed to IN.
The same route map should be set on the E1 as well by pointing ASN of ISP1 as an as-path value.
Will this all work correctly along with the rest configuration provided here by you?
Hello
The example 2 configuration should indeed work, just append the config ( access-list) to accommodate what prefix(s) you would like to take the non default ISP path
Kind Regards
Paul
Thank you, Really helpful.
