BGP.is it mandatory to do clear ip bgp after adding new network
webstd.design
<RouterID 10.10.10.1>----eBGP----<RouterID 10.10.1.1>---adding new subnet 10.10.1.2
In case if we add new subnet like 10.10.1.2 into bgp using network command should we do clear ip bgp x.x.x.x?
if you modify a policy then you must do either a soft reset or a route-refresh( with clear ip bgp x.x.x.x in or clear ip bgp x.x.x.x out).
Regards.
Alain
8 Replies 8
   No need. Just make sure that the new "network" you added is already in RIB.
HTH,
Toshi
cadet alain
no it isn't and as a side note as most routers support route refresh you should be better doing a clear ip bgp x.x.x.x in or
clear ip bgp x.x.x.x out which are soft resets which don't tear the peering.
Regards.
Alain.
--10.10.10.2----eBGP----10.10.1.2-----adding new subnet 10.10.1.20/30
I'm not able to find subnetwork 10.10.1.20/30 with command below:
10.10.10.1> sh ip bgp neigh 10.10.1.2 routes
Also this command doesn't show route 10.10.1.20/30
10.10.1.1> sh ip bgp neigh 10.10.1.2 advertised-routes
Can see 10.10.1.20/30 in below
10.10.1.1>sh ip bgp
Can't see 10.10.1.20/30 in below
10.10.10.1>sh ip bgp
What should I within clear ip bgp? or any other usefull command? Any glue?
clear ip bgp is not mandatory the only the important thing is the mask in the network statment and in the routing table should be same.
syed.
aren't you filtering the prefixes advertised to  10.10.1.2?
Outgoing route-map, filter-list, etc.?
You could try
clear ip bgp 10.10.1.2 soft
but it should not be necessary if the  10.10.1.20/30 was in the RIB at the moment you added
network 10.10.1.20 mask 255.255.255.252
to you BGP config.
Another low probability  chance:
Aren't you receiving the same prefix from 10.10.1.2 already with better BGP attributes?
In that way you would not advertise  the prefix back.
Or isn't the prefix next-hop pointing to 10.10.1.2?
HTH,
Milan
10.10.1.20 is directly connected network on RouterID 10.10.1.1
I don't think that I should add this route into IGP, as we use eBGP between RouterID 10.10.1.1 and RouterID 10.10.10.1
If we modify policy - should we do clear ip bgp soft?
Regards.
Alain
