BGP loadbalancing
grapevine
Suppose there are two routers R1 and R2 at the customer edge each running bgp
How can we configure loadbalancing and failover in case of link failure
balaji.bandi
here is a document to start with : ( Both case displayed here.....going to same ISP or different ISP)
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13762-40.html
BB
Joseph W. Doherty
In the case of link failure, is routing information is shared between R1 and R2, fail over should normally be fine.
In case of load balancing, Balaji's reference shows all but (I believe) the way to load balance to different ASs. The latter is accomplished by using a "hidden" command (which I forget the exact syntax for, but it's noted in different posts on these forums).
