BGP & memory req'd
peter290457
Community Member
I have a question about BGP & memory requirements: A router is being sent a large number of routes (for example, all the Internet route) but has an input filter only allowing about 10 routes in.
Does the router require enough memory (& cpu) to handle all the routes being sent to it?
Peter
Georg Pauwen
Hello Peter,
to handle a full BGP routing table, a minimum of 128MB of RAM is recommended. 10 routes should normaly not be a problem, although other attributes, such as the number of BGP peers, influence the memory utilization as well.
Check this document, it discusses the BGP memory utilization issue:
Achieve Optimal Routing and Reduce BGP Memory Consumption
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094a83.shtml
HTH,
GP
