BGP - Multihop and Multipath -
yhaas1
hope you can help me. I want to do bgp with two C1111 Routers with two links between the routers.
First direct connected and secound via multihop.
But I am not able to bring be secound link up.
Setup like this:
All Networks are /28.
This is my BGP config:
router bgp 100
bgp log-neighbor-changes
neighbor 10.31.4.18 remote-as 200
neighbor 10.31.4.18 fall-over bfd
neighbor 10.31.4.65 remote-as 200
neighbor 10.31.4.65 ebgp-multihop 4
neighbor 10.31.4.65 fall-over bfd
address-family ipv4
network 10.31.4.0 mask 255.255.255.240
network 10.31.4.16 mask 255.255.255.240
neighbor 10.31.4.18 activate
neighbor 10.31.4.65 activate
maximum-paths eibgp 5
exit-address-family
router bgp 200
neighbor 10.31.4.17 remote-as 100
neighbor 10.31.4.17 fall-over bfd
neighbor 10.31.4.49 remote-as 100
neighbor 10.31.4.49 ebgp-multihop 4
neighbor 10.31.4.49 fall-over bfd
address-family ipv4
network 10.31.4.32 mask 255.255.255.240
neighbor 10.31.4.17 activate
neighbor 10.31.4.17 soft-reconfiguration inbound
neighbor 10.31.4.49 activate
neighbor 10.31.4.49 soft-reconfiguration inbound
exit-address-family
Maybe there is only a simple trick I don't see...
Thanks!
27 Replies 27
Hi @yhaas1 ,
Can you post a "show bgp ipv4 uni summary" output?
bgp with fall-over BFD have two
single hop command "fall-over bfd"
multi-hop command "fall-over bfd multi-hop"
the same BGP peer "which identify  by router-id" must have one single BGP session to any other Peer,
here you config two session between same two peer.
this config is wrong, you need to config any IGP between the two peer and use loopback as update source and loopback for other peer as neighbor.
this achieve the two link IGP one BGP session between two Peer.
Can yoy try to remove:
ip route static bfd 10.31.4.49 10.31.4.65 unassociate
ip route static bfd 10.31.4.65 10.31.4.49 unassociate
Ventsi
I tried this but no change.
Freind you can not do two bgp session between two peer.
There must be one session, and to improve that remove direct connect link config bgp with bfd "dont forget multihop" and it will work.
@MHM Cisco World ,
You can certainly have more than one session between two BGP peers, as long as they do not use the same end points.
This make loop, and hence it is not possible.
RA send route to RB,
RB resend it to RA since it assume it different peer.
So if there are multi link then we run any igp or config static and config loopback in both peer.
This loopback will use as update source and as nieghor ip address.
Hi @MHM Cisco World ,
There are a few use cases, where I have used multiple BGP sessions between the same two routers in the past. This will not create a loop.
RA rejects the route as the AS-PATH contains it own ASN.
I think you talk about multi session bgp with different address family not same address family, am I right?
But here he use only one address family ipv4.
No, I am talking about two BGP IPv4 unicast sessions between the same pair of routers. This works and I have used it for a few use cases in the past. This is will work without any issue.
vencislav.metev
Can you try telnet from 10.31.4.65 to 10.31.4.49 on port 179?
Or vice versa.
Ventsi
do
show bgp ipv4 unicast neighbor
see if the multisession is enable or disable.
