BGP not forming sessions
hfakoor222
Doing a lab.
R9 is not forming sessions with R10 and R11:
here is debug on R9
Jun 8 23:00:58.002: BGP: 192.10.10.10 Active open failed - tcb is not available, open active delayed 10240ms (35000ms max, 60% jitter)
*Jun 8 23:00:58.002: BGP: ses global 192.10.10.10 (0xDCE67060:0) act Reset (Active open failed).
Any advice appreciated (it's just a lab, but if you have time, I like the learning experience)
here is the show run:
R9
interface Loopback0
description Network Admin1
ip address 192.9.9.9 255.255.255.255
ipv6 address 2010:CAFE:9::9/128
interface Loopback1
description Test Network
ip address 192.199.199.199 255.255.255.255
interface Loopback100
description Metric Test
ip address 192.99.99.99 255.255.255.255
interface Ethernet0/0
ip address 192.168.10.9 255.255.255.252
ipv6 address 2001:CC1E:CAFE::9/126
ipv6 address 2001:CCCC:CAFE::1/126
interface Ethernet0/1
ip address 192.168.10.2 255.255.255.252
ipv6 address 2001:CC1E:CAFE::2/126
bfd interval 60 min_rx 60 multiplier 8
interface Ethernet0/2
no ip address
shutdown
interface Ethernet0/3
no ip address
shutdown
router eigrp San_Francisco_HQ
address-family ipv4 unicast autonomous-system 150
af-interface default
authentication mode hmac-sha-256 EIGRP
exit-af-interface
af-interface Ethernet0/1
bfd
exit-af-interface
topology base
redistribute connected metric 1 1 1 1 1 route-map Metric
offset-list 1 in 2147483647 Ethernet0/1
exit-af-topology
network 192.9.9.9 0.0.0.0
network 192.168.10.0 0.0.0.3
network 192.168.10.8 0.0.0.3
network 192.199.199.199 0.0.0.0
eigrp router-id 192.9.9.9
exit-address-family
router bgp 64784
bgp router-id 192.9.9.9
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor PEER-INTERNAL peer-group
neighbor PEER-INTERNAL remote-as 64784
neighbor PEER-INTERNAL update-source Loopback0
neighbor 192.8.8.8 peer-group PEER-INTERNAL
neighbor 192.10.10.10 peer-group PEER-INTERNAL
neighbor 192.11.11.11 peer-group PEER-INTERNAL
address-family ipv4
neighbor PEER-INTERNAL send-community
neighbor 192.8.8.8 activate
neighbor 192.10.10.10 activate
neighbor 192.11.11.11 activate
exit-address-family
ip forward-protocol nd
ip bgp-community new-format
no ip http server
no ip http secure-server
ip prefix-list Metric seq 5 permit 192.99.99.99/32
access-list 1 permit 192.188.188.188
route-map Metric permit 10
match ip address prefix-list Metric
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
transport input all
R11
interface Loopback0
description Internal DNS Server
ip address 192.11.11.11 255.255.255.255
ipv6 address 2010:CAFE:11::11/128
ip address 192.168.10.26 255.255.255.252
ipv6 address 2001:CC1E:CAFE::26/126
ip address 192.168.10.18 255.255.255.252
ipv6 address 2001:CC1E:CAFE::17/126
ip address 192.168.10.22 255.255.255.252
ip address 155.84.74.13 255.255.255.252
interface Ethernet1/0
bandwidth 1
ip address 140.60.88.14 255.255.255.252
shutdown
interface Ethernet1/1
no ip address
shutdown
interface Ethernet1/2
no ip address
shutdown
interface Ethernet1/3
no ip address
shutdown
exit-af-interface
topology base
distribute-list prefix NETWORK gateway GATEWAY in Ethernet0/2
exit-af-topology
network 192.11.11.11 0.0.0.0
network 192.168.10.18 0.0.0.0
network 192.168.10.22 0.0.0.0
network 192.168.10.26 0.0.0.0
metric rib-scale 153
eigrp router-id 192.11.11.11
exit-address-family
router bgp 64784
neighbor 192.9.9.9 peer-group PEER-INTERNAL
neighbor 192.10.10.14 peer-group PEER-INTERNAL
address-family ipv4
neighbor 192.9.9.9 activate
neighbor 192.10.10.14 activate
exit-address-family
no ip http server
route-map list permit 5
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
transport input all
end
R10
interface Loopback0
description Finance User
ip address 192.10.10.10 255.255.255.255
ipv6 address 2010:CAFE:10::10/128
ip address 155.84.74.9 255.255.255.252
ip address 192.168.10.25 255.255.255.252
ipv6 address 2001:CC1E:CAFE::25/126
ip address 192.168.10.14 255.255.255.252
ipv6 address 2001:CC1E:CAFE::13/126
no ip address
shutdown
exit-af-interface
topology base
exit-af-topology
network 192.10.10.10 0.0.0.0
network 192.168.10.14 0.0.0.0
network 192.168.10.25 0.0.0.0
eigrp router-id 192.10.10.10
exit-address-family
router bgp 64784
neighbor 155.84.74.10 remote-as 15789
address-family ipv4
neighbor 155.84.74.10 activate
exit-address-family
no ip http server
ip prefix-list GATEWAY seq 5 permit 192.168.10.13/32
ip prefix-list NETWORK seq 5 deny 192.199.199.199/32
ip prefix-list NETWORK seq 10 permit 0.0.0.0/0 le 32
control-plane
R11
R9
you use different subnet in both router, it can be true in case the SW is L3 not L2, so are SW between R9 and R11 L3 or L2 SW?
5 Replies 5
Router1#telnet x.x.x.x 179
Check if the tcp port is open or not
I just copy pasted the configuration for R11 it was giving to much of a headache
M02@rt37
Hello @hfakoor222,
Please, confirm that there is IP connectivity between the loopback interfaces used as BGP router IDs on R9, R10, and R11. You can verify this by pinging the loopback addresses from each router.
Thanks.
Best regards
R11
R9
I noticed today I had wrong ip addresses assigned.
