BGP over Tunnel
mautez_mah
dears
If I have two links , to ISP using BGP will apply Failover ,
I told ISP that I will split each link into two tunnels but they said it is not recommended at all , specifically using BGP Faliover , they said it may also affect Application
is this True ? why ? Thanks
5 Replies 5
balaji.bandi
what kind of Links ?  Etherent delivery ? why you need to tunnel with ISP ?
BB
@balaji.bandi Thanks
links is L2 connection ( DIA ) for wan connectivity.
I need Tunnel to get two services , one MPLS and other is Internet
MPLS and Internet from same provider ?
you like to peer BGP over Tunnel ?
BB
mautez_mah
yes
I will use Internet and MPLS for both links
so I can have redundancy in both ,
my question is : is there any issue with Tunnel configuration
Your are using the internet to access the HQ ?
One link that connect to SP use MPLS
other connect to ISP use DMVPN
ask the ISP for this solution.
