GNS3 OSPFv3 doesn't count link connected to vpc
michaeld99810
this is the running config of a multi layer switch :
Building configuration...
Current configuration : 2271 bytes
! Last configuration change at 18:48:49 IST Mon Mar 21 2022
version 15.2
service compress-config
hostname D1
boot-start-marker
boot-end-marker
logging discriminator EXCESS severity drops 6 msg-body drops EXCESSCOLL
logging buffered 50000
logging console discriminator EXCESS
no aaa new-model
clock timezone IST 2 0
vtp interface e1/0
no ip icmp rate-limit unreachable
no ip domain-lookup
ip cef
ipv6 unicast-routing
ipv6 cef
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
ip tcp synwait-time 5
interface Port-channel1
 switchport mode trunk
 switchport nonegotiate
interface Ethernet0/0
 no switchport
 ip address 10.10.0.2 255.255.255.252
 ip ospf dead-interval 10
 ip ospf cost 1
 duplex auto
 ipv6 address FE80::D1:2 link-local
 ipv6 address 2001:DB8:ACAD:1001::2/64
 ipv6 ospf 123 area 1
interface Ethernet0/1
 no switchport
 ip address 10.10.1.1 255.255.255.0
 duplex auto
 ipv6 address FE80::D1:1 link-local
 ipv6 address 2001:DB8:ACAD:1002::1/64
interface Ethernet0/2
 switchport access vlan 20
 switchport mode access
interface Ethernet0/3
 switchport access vlan 50
interface Ethernet1/0
 channel-group 1 mode active
interface Ethernet1/1
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet2/0
interface Ethernet2/1
interface Ethernet2/2
interface Ethernet2/3
interface Ethernet3/0
interface Ethernet3/1
interface Ethernet3/2
interface Ethernet3/3
interface Vlan1
 no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ipv6 router ospf 123
 router-id 1.1.1.2
 area 1 stub
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
e0/1 is connected to a vpc
but the command show ipv6 ospf database
it doesn't show that link why is that ?
balaji.bandi
Can you show us the output from both the sides ?
BB
it L2 port this is why it not show in OSPF, use no switch port and apply IP "if the vPC support L3" and check OSPF again.
or config SVI use the vPC trunk.
