BGP problem address family ipv4
santox
Hi I have a Cisco ASR1001 pppoe server with 2 BGP peering to others two routers.
In Cisco I setup bgp+adress family but when my client start pppoe sessions and router assign to them public ips, 1001 dont propagate these ips /32.
If, in
address family ipv4
I had single /32 ip instead of /24 prefix it works. (ex 100.100.100.0/21)
router bgp 666
bgp router-id 10.250.1.1
no bgp enforce-first-as
bgp log-neighbor-changes
neighbor 10.20.1.13 remote-as 666
neighbor 10.20.1.13 description ** IBGP TO ASR1006 VLAN6 **
neighbor 10.20.1.13 update-source TenGigabitEthernet0/0/0.6
neighbor 10.20.1.13 timers 20 60
neighbor 10.20.1.17 remote-as 666
neighbor 10.20.1.17 description ** IBGP TO ASR1006 VLAN5 **
neighbor 10.20.1.17 update-source TenGigabitEthernet0/0/0.5
neighbor 10.20.1.17 timers 20 60
address-family ipv4
network 10.250.1.1 mask 255.255.255.255
network 100.100.100.0 mask 255.255.248.0
Can I propagate single ips only if customers go online
so when ip is directly connected to the router?
thank you and good work to all
Do yoh try
redistribute connect?
When clients connect it route is add and
will advertise it automatic.
7 Replies 7
santox
only if I add this command
1001 propagate the customer ip
ex.
customer have assign from pool 100.100.100.1, I must add
address-family ipv4
network 100.100.100.1 mask 255.255.255.255
thank you
balaji.bandi
not sure i have not come across this scenario - i do not believe BGP is right choice here i guess for the netmask you looking
as per i know BGP only acccept /24 and more. (i hear some provider can accept /25 and /28 (not saw /32)
BB
Hi thanks for reply
is internal BGP not eBGP.
connection with providers is 1006 job.
1001 will use only for pppoe sessions.
Do yoh try
hi,
thank you I dont know why I dont use this command first. Always enable in mikrotik routers..
now I add this command and I see all prefixes when pppoe client is active!
thank you and good work!
Harold Ritter
Hi @santox ,
The reason it doesn't work with the network statement for the /21 is that you need a route matching that same prefix/prefix length in the routing table. It would probably better to advertise only one block (/21) than to advertise lots of individual routes (/32). To do that you will need to configure a static route for the /21 to null0 as follow:
ip route 100.100.100.0 255.255.248.0 null0
router bgp 666
address-family ipv4 unicast
Hi Harold
I use command
redistribute connected
and now I have scenario I want.
If /32 is announce to 1001 meaning that client is connect to him and can go to internet via 1006 router.
If not, /24 prefix continue to routing to other network
thank you and good day!
