BGP problem
julxu
Geeting
I want one route to go a private network, not default. but, I have problem to correct it. could anyone advice me:
#show ip bgp
network                           Net Hop                 metric              locaPrf  weight     path
*>0.0.0.0                         202.111.111.111  4294967295  30          0             1111 i
*> 10.1.1.2/30                0.0.0.0                    0                                    32768    i
*>203.111.111.111/26  10.1.1.2                100                   100       0             64624 ?
the second route is static route from another bgp route, redistribited to here.
*>203.111.111.111/26   132.111.111.111  100                              32768      ?
Any comments will be appreciated
Thanks in advance
julxu
Roman Rodichev
Level 7
Level 7
Some redistributed static or IGP routes will have a next hop of 0.0.0.0. That 0.0.0.0 doesn't mean "default route". If a packet comes into the router for that destination, you should already have another non-BGP route in the routing table for routing that packet.
Roman Rodichev
Level 7
Level 7
