BGP Question- Urgent
vinodbharwani
Hi Friend
I have One office & it is connected by two different ISP1 and ISP 2 ( Different AS number ), I have two 2 mb link between them. Now i want to configure traffic in such way one link use only 60 % with ISP1 and other link to IPS2 is using 40% traffic, How i can configure this ?
-V
sirdudesly
Level 2
Level 2
quality of service?
shivlu jain
Level 5
Level 5
or you can use the policy based routing. In PBR you can match the source and assign the next hop addresses.
regards
shivlu
bvsnarayana03
Level 5
Level 5
You may be having definite reasons for doin this, otherwise make full use of the pipe you are paying for. There are some QoS techniques for doing this. Rate-limiting, shaping & policing are some features.
Refer this link for understanding:
http://www.cisco.com/en/US/docs/ios/12_0/qos/configuration/guide/qcpolts.html
Joseph W. Doherty
For outbound, but not practical for inbound, if your routers support OER/PfR, you can configure load ratios.
