BGP Route Injection
alfredobosca
I know that route injection let us to insert prefixes more specific withouth appear in the routing table. Now I am practising but isn't working fine.
The steps are:
  1.  Configure a prefix-list listing all more-specific prefixes
  2.  Configure a ROUTE-MAP using the prefix-list of above
  3.  Configure a second prefix-list with aggregate prefix
  4.  Configure a thirth prefix-list to matching the advertising-router of all more-specific prefixes.
  5.  Second ROUTE-MAP using the second and thirth prefix-lists.
  6.  Finally use both ROUTE-MAPS with this syntax:
bgp inject-map HOSTS exist-map SUBNET copy-attributes
So I will summarize on R2 Device and will configured Route-Injection on R3 devices. At the end I will go to R4 device to verify that works.
R2
Loopback1                  10.10.10.1      YES NVRAM  up                    up
Loopback2                  10.10.10.129    YES NVRAM  up                    up
Loopback3                  10.10.11.1      YES manual up                    up
Loopback4                  10.10.12.1      YES manual up                    up
R2#sh ru | s bgp
router bgp 123
 no synchronization
 bgp log-neighbor-changes
 network 1.1.1.1 mask 255.255.255.255
 aggregate-address 10.10.8.0 255.255.248.0 summary-only
 redistribute connected
 neighbor my-group peer-group
 neighbor 1.1.1.1 remote-as 123
 neighbor 1.1.1.1 peer-group my-group
 neighbor 1.1.1.1 password 7 1414110209
 neighbor 1.1.1.1 update-source Loopback0
 neighbor 3.3.3.3 remote-as 123
 neighbor 3.3.3.3 peer-group my-group
 neighbor 3.3.3.3 password 7 0458080F0A
 neighbor 3.3.3.3 update-source Loopback0
 no auto-summary
R3
router bgp 123
 no synchronization
 neighbor 2.2.2.2 remote-as 123
 neighbor 2.2.2.2 password 7 1511080501
 neighbor 2.2.2.2 update-source Loopback0
 neighbor 4.4.4.4 remote-as 45
 neighbor 4.4.4.4 disable-connected-check
 neighbor 4.4.4.4 update-source Loopback0
 no auto-summary
ip prefix-list AGGREGATE seq 5 permit 10.10.8.0/21
ip prefix-list HOSTS seq 5 permit 10.10.10.0/24
ip prefix-list HOSTS seq 10 permit 10.10.11.0/24
ip prefix-list adv-router seq 5 permit 172.26.1.1/32 //IP of neighbor R2
ip prefix-list adv-router seq 10 permit 2.2.2.2/32//IP of neighbor R2 (loopback)
route-map SUBNET permit 10
 match ip address prefix-list AGGREGATE
 match ip route-source prefix-list adv-router
route-map HOSTS permit 10
 match ip address prefix-list HOSTS
I keep on without see the HOSTS prefixes (more specific). I have already restart the BGP sessions without success.
R4#show ip bgp
BGP table version is 56, local router ID is 4.4.4.4
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 1.1.1.1/32       3.3.3.3                                0 123 i
*> 2.2.2.2/32       3.3.3.3                                0 123 ?
*> 10.10.8.0/21     3.3.3.3                                0 123 i
*> 172.26.1.0/30    3.3.3.3                                0 123 ?
*> 172.26.1.4/30    3.3.3.3                                0 123 ?
Best regards,
7 Replies 7
Julio E. Moisa
Have you verified if the network 10.10.8.0/21 is included on the BGP table? Your Condition is: advertise HOSTS if SUBNET exist (or learned)
Could you please share the output of: show ip bgp
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Of course,
As you can see in output of "show ip bgp" on R4 device appear the 10.10.8.0/21
Best regards,
post the full configs of both routers, R2 and R3, you are missing something. Your update source on R2 is Loopback 0, but I don't see Loopback 0 in your configuration...
Thank you Alfredo,
Please let me lab it and share my findings.
try the below on R3 (I have changed the names of the route maps for clarity):
router bgp 123
no synchronization
bgp inject-map ORIGINATE exist-map LEARNED_PATH
route-map LEARNED_PATH permit 10
match ip address prefix-list ROUTE
match ip route-source prefix-list ROUTE_SOURCE
route-map ORIGINATE permit 10
set ip address prefix-list ORIGINATED_ROUTES
ip prefix-list ROUTE seq 5 permit 10.10.8.0/21
ip prefix-list ORIGINATED_ROUTES seq 5 permit 10.10.10.0/24
ip prefix-list ORIGINATED_ROUTES seq 10 permit 10.10.11.0/24
ip prefix-list ROUTE_SOURCE seq 10 permit 2.2.2.2/32
Is the same config that I applied on GNS3 and it seems doesn't works.
Best regards,
paranoikN
@alfredobosca you need to use:
 SET ip address prefix-list HOSTS
instead MATCH... in route-map hosts.
