BGP route map send community config
hmc250000
We are trying to configure eBGP peering and setting a community string.  I'm not very familiar with setting community strings in BGP.
The community string seems to change from this > set community 64612:100 to this > community 4234412132
IS this behavior correct?
Router A (Local) AS is 64612
Router B (Remote) AS is 64512
The BGP config on router A is as follows:
router bgp 64612
neighbor 192.168.200.2 56.250 remote-as 64512
address-family ipv4
neighbor 192.168.200.2 route-map Test
neighbor 192.168.200.2 send-community both
network 192.168.200.0 mask 255.255.255.0
route-map Test permit 10
match ip address prefix-list Test
ip prefix Test permit 10 192.168.200.0/24 le 32
However the "show route-map" output on the router shows like this:
sh route-map
route-map Test, permit, sequence 10
Match clauses:
ip address prefix-lists: Test
Set clauses:
Policy routing matches: 0 packets, 0 bytes
Ip bgp-community new-format
This command you need
