Cisco BGP Router Recommendations
leon471
Hi all, we are a small hosting provider and have recently decided to bring in our own bandwidth versus solely utilizing datacenter provided bandwidth. We will be peering with the datacenter and another ISP, both at 150 Mbps. I'm planning on taking in full routes from each. What model would you all recommend as a properly sized solution? ASR1001? 7300 series?
Thanks all for your input
 ASR1002HX can be a good fit for this.
