BGP route maps for setting local pref
pbrown
I want to set a local pref to 90 in one of my links. If I just want to match everything do I really need a match clause?
Will this work?
router bgp 65000
neighbor 10.10.10.10 remote-as 65001
neighbor 10.10.10.10 route-map SET-LOCAL-PREF in
route-map SET-LOCAL-PREF permit 10
set local-preference 90
Patrick
ekiriakos
That will work fine
Rgds
E.
mheusinger
Level 10
Level 10
this will work, because a route-map statement without match condition will match everything.
Hope this helps! Please rate all posts.
Regards, Martin
fabricio.monte
Hello Patrick,
Your config will work.
If you want to match everything, you don't need to use the "match" statement, just use the "set" statement.
You will need to use the "match" only if you want to select something.
Fabricio
Network Analyst
