BGP route propogation
vishal_bhugra
Hello Experts
Attached is the configuration of my routers.
I have configured iBGP between the routers and advertised the loopback. But my loopbacks are not getting advertised.
following is the output from my 2 routers:-
Rack1R1#sh ip bgp summ
BGP router identifier 150.1.1.1, local AS number 100
BGP table version is 1, main routing table version 1
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
155.1.23.2      4   100     140     140        1    0    0 00:41:03        0
155.1.23.3      4   100     136     137        1    0    0 01:29:47        0
155.1.45.5      4   100     133     134        1    0    0 01:30:18        0
155.1.146.4     4   100     139     139        1    0    0 01:30:17        0
155.1.146.6     4   100     130     131        1    0    0 01:30:17        0
Rack1R1#sh ip bgp
Rack1R1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     155.1.0.0/24 is subnetted, 9 subnets
C       155.1.146.0 is directly connected, FastEthernet2/0
D       155.1.23.0 [90/2681856] via 155.1.13.3, 00:35:22, Serial0/1
C       155.1.13.0 is directly connected, Serial0/1
C       155.1.0.0 is directly connected, Serial0/0.1
D       155.1.5.0 [90/2172416] via 155.1.0.5, 00:35:21, Serial0/0.1
D       155.1.58.0 [90/2172416] via 155.1.0.5, 00:35:21, Serial0/0.1
D       155.1.45.0 [90/2172416] via 155.1.146.4, 00:35:21, FastEthernet2/0
D       155.1.37.0 [90/2172416] via 155.1.13.3, 00:35:24, Serial0/1
D       155.1.67.0 [90/284160] via 155.1.146.6, 00:35:24, FastEthernet2/0
     150.1.0.0/24 is subnetted, 1 subnets
C       150.1.1.0 is directly connected, Loopback0
Rack1R2#sh ip bgp summ
BGP router identifier 150.1.2.2, local AS number 100
155.1.13.1      4   100      45      45        1    0    0 00:41:50        0
155.1.23.3      4   100     134     134        1    0    0 02:11:12        0
155.1.45.5      4   100     130     130        1    0    0 02:06:52        0
155.1.146.4     4   100     133     133        1    0    0 02:09:08        0
155.1.146.6     4   100     128     128        1    0    0 02:04:18        0
Rack1R2#sh ip bgp
Rack1R2#sh ip route
D       155.1.146.0 [90/2684416] via 155.1.23.3, 00:34:38, Serial0/1
                    [90/2684416] via 155.1.0.5, 00:34:38, Serial0/0.1
C       155.1.23.0 is directly connected, Serial0/1
D       155.1.13.0 [90/2681856] via 155.1.23.3, 00:34:38, Serial0/1
D       155.1.5.0 [90/2172416] via 155.1.0.5, 00:34:38, Serial0/0.1
D       155.1.58.0 [90/2172416] via 155.1.0.5, 00:34:38, Serial0/0.1
D       155.1.45.0 [90/2681856] via 155.1.0.5, 00:34:39, Serial0/0.1
D       155.1.37.0 [90/2172416] via 155.1.23.3, 00:34:39, Serial0/1
D       155.1.67.0 [90/2710016] via 155.1.23.3, 00:34:39, Serial0/1
                   [90/2710016] via 155.1.0.5, 00:34:39, Serial0/0.1
C       150.1.2.0 is directly connected, Loopback0
what could be the issue.
you have /32 advertised under bgp network statement..
network 155.1.1.1 mask 255.255.255.255
but the routing table entry is /24  or some other mask (not really sure)
the network statement should have an exact match on the routing table (via igp or static or connected routes) in order to advertise...
to correct this, either change loopback to /32 or
change the mask on the network command to /24...it's your choice
Regards Vinayak
5 Replies 5
blau grana
Level 7
Level 7
configs which you have attached can not be opened.
From outputs which you have provided we can see that all bgp peers are in same AS 100. What does topology look like? Did you configure iBGP full mesh?
Try theese commands:
#debug ip bgp update - to see BGP updates and maybe reason why they are denied
#show ip bgp neighbors IP_ADDRESS advertised-routes - show what prefixes are sent to defined neighbor if any
Best Regards
Please rate helpful posts
Best Regards Please rate all helpful posts and close solved questions
Ajay Raj
The attachments can't be opened. Can I know how the networks are being advertised. Is it by using network command. If so check whether the subnet mask in the network command is same as the subnet mask in Routing table.
Share sh ip bgp | sec bgp  or sh ip bgp | beg bgp    outputs also.
Please check this and let me know.
Hello
The networks are advertised using network statments.
RACK1R1#
router bgp 100
no synchronization
bgp log-neighbor-changes
neighbor 155.1.23.2 remote-as 100
neighbor 155.1.23.3 remote-as 100
neighbor 155.1.45.5 remote-as 100
neighbor 155.1.146.4 remote-as 100
neighbor 155.1.146.6 remote-as 100
no auto-summary
R2
router bgp 100
no synchronization
network 155.1.2.2 mask 255.255.255.255
neighbor 155.1.146.1 remote-as 100
no auto-summary
Regards Vinayak
Ya I tried same thing and it does work.
Thanks everyone.
