cisco 881
danut.nastasa
Who can help me in configurating a cisco 881 router?
I'm connected to the internet with a static ip, but i dont have acces to internet from my pc..:D
4 Accepted Solutions
replace
access-list 23 permit any
with
access-list 23 permit 192.168.250.0 0.0.0.255
add static default route
ip route 0.0.0.0 0.0.0.0 NEXT_HOP_IP Fa4
And last thing, your nat POOL looks strange, I assume that you own only one IP from defined range.
Delete this line:
ip nat pool NATPOOL 89.X.X.X netmask 255.255.255.248
And next line replace like this:
no ip nat inside source list 23 pool NATPOOL overload
ip nat inside source list 23 interface Fa4 overload
Best Regards
Please rate helpful posts
Best Regards Please rate all helpful posts and close solved questions
ip route 0.0.0.0 0.0.0.0 192.168.1.50
ip route 0.0.0.0 0.0.0.0 192.168.1.200
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 0.0.0.0 0.0.0.0 192.168.1.0
ip route 0.0.0.0 0.0.0.0 dhcp
Why are you pointing default route to LAN? Your WAN interface is Fa4 so entire internet traffic should go out through that interface.
I noticed that you obtain WAN IP from DHCP, do you also obtain default route same way?
If you do not configure routing to internet properly, your internet connection will not work.
Best Regards
Get rid of all these:
And just keep this one:
You must be in configuration mode to do this:
at the router prompt, enter the word 'enable' then hit return:
To remove them use the no command in front of each line:
no ip route 0.0.0.0 0.0.0.0 192.168.1.50
no ip route 0.0.0.0 0.0.0.0 192.168.1.200
no ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip route 0.0.0.0 0.0.0.0 192.168.1.0
ip dhcp pool DHCP
   import all
   network 192.168.250.0 255.255.255.0
   default-router 192.168.250.1
   dns-server 192.168.250.253 192.168.250.254
   lease 0 2
192.168.250.253
192.168.250.254
Are u sure that DNS will works.  I think so u must contact you ISP and confirm DNS Server IP from them.
Jawad
11 Replies 11
John Blakley
How are you configuring it? Through the cli? You'll need to configure nat in order for you computer to get out. Can you post what you have configured already? (Get rid of private information though.)
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
u can add default route
0.0.0.0 0.0.0.0 (Next Hope Your ISP GW)
IP Access-list Internet
Permit ip any any
ip nat inside source list internet (Interface to which ur ISP is connected) fastethernet 0/0 overload
Your Inside Interface
ip nat inside
Your Outside Interface
Ip nat outside
Jawad
this is what i've tried so far but with no luck!
i did this from youtube tutorials, i'm a noob in cisco configuration
version 12.4
no service pad
hostname R1
boot-start-marker
boot-end-marker
crypto pki trustpoint TP-self-signed-2263202332
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2263202332
revocation-check none
rsakeypair TP-self-signed-2263202332
crypto pki certificate chain TP-self-signed-2263202332
certificate self-signed 01
quit
ip source-route
ip dhcp excluded-address 192.168.250.0
ip dhcp excluded-address 192.168.250.1
no ip domain lookup
ip dhcp pool DHCP
import all
lease 0 2
ip cef
no ipv6 cef
license udi pid CISCO881-K9 sn FCZ1417C10S
licence boot module c880-data level adviperservices
username cisco privilege 15 secret 0 cisco
username dan privilege 15 password 0 admin
interface FastEthernet0
description OPT0
switchport mode access
switchport access vlan 1
no shutdown
interface FastEthernet1
description OPT1
no shutdown
interface FastEthernet2
description OPT2
no shutdown
interface FastEthernet3
description OPT3
no shutdown
interface FastEthernet4
description WAN
ip address 89.X.X.X 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no shutdown
interface Vlan1
ip address 192.168.250.1 255.255.255.0
ip tcp adjust-mss 1452
ip nat inside
archive
log config
hidekeys
ip forward-protocol nd
ip http server
ip http access-class 23
ip http secure-server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 100 permit ip any any
ip routing
alias exec sr show run
alias exec si show interfaces
alias exec sip show ip protocols
alias exec sir show ip route
alias exec sia show ip arp
alias exec s show ip int br
alias exec sd show debugging
alias exec st show ip nat translations
no cdp run
line con 0
logging synchronous
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
transport input telnet ssh
scheduler max-task-time 5000
end
danut.nastasa
if i'm connected to a lan network (192.168.1.1, 255.255.255.0, gw 192.168.1.50 dhcp enabled)  how can i assign an ip address to my FA4 (wan) interface ?
replace
with
Delete this line:
Best Regards
still doesnt work...now i'm conncted to a LAN network with internet access....(192.168.1.50-def gw, 192.168.1.200 dns server , dhcp server enable) but i still can't  connect my pc to the internet via cisco which is connected on lan. but i can ping all the others pc's on LAN. Any ideeas ?
version 12.4
no service pad
hostname R1
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
ip dhcp pool DHCP
   import all
   lease 0 2
ip cef
no ip domain lookup
no ipv6 cef
username cisco privilege 15 secret 5 $1$yFuG$cio0V5RCGol./4BVWEp0G0
archive
log config
  hidekeys
description OPT0
description OPT1
description OPT2
description OPT3
description WAN
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
ip http server
ip nat inside source list 23 interface FastEthernet4 overload
no cdp run
Best Regards
above are all the settings that are made on the router...so i'm not realy sure how to do what u just said...
ip dhcp pool DHCP
   import all
   lease 0 2
192.168.250.253
192.168.250.254
Jawad
it apears that my dns was with problem...thanks to alll for your help!!
