BGP route selection
cheung.kelvin
Dear Community
Pls see the "show ip bgp". For me the path No.2 and No.4 have the same conditions, why path No.4 is the best. What is the mechanism to choose it?
R1>sh ip bgp 10.20.0.0/19
BGP routing table entry for 10.20.0.0/19, version 18108
Paths: (4 available, best #4, table Default-IP-Routing-Table)
Not advertised to any peer
17668 64513 64513 64513 64513 64513, (aggregated by 64513 10.20.4.129)
10.255.66.9 from 10.255.66.9 (202.168.55.242)
Origin IGP, localpref 100, valid, external, atomic-aggregate
17668 64513 64513 64513, (aggregated by 64513 10.20.4.129)
10.255.66.2 from 10.255.66.2 (202.168.55.243)
10.255.66.10 from 10.255.66.10 (202.168.55.243)
10.255.66.1 from 10.255.66.1 (202.168.55.242)
Origin IGP, localpref 100, valid, external, atomic-aggregate, best
R1>
Kelvin Cheung
cjnwodo
Kelvin,
Looks like No. 4 was chosen because the prefix was received from a BGP neighbour with a lower router id [10.255.66.1] whereas No.2 has a router id of 10.255.66.2]. Cisco BGP best path selecyion algorithm number 11.
Here's a link to the Cisco BGP best path selection algorithm. Hopefully it will make it clearer to you.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml
you should check,
Which router is closer as per the IGP metric
And the router ID --(as said above lower ID wins)
Narayan
Dear HTH
Thanks a lot..
You are right....
Kelvin Cheung
Dear Cjnwodo
Thanks for your help. It is great....
Kelvin Cheung
