BGP routes not being redistributed into OSPF
CiscoBrownBelt
Level 6
Level 6
See attached topology of lab.
I am running OSPF on routers 1-4, and 10; BGP on R4-6.
I am using Lo0 for BGP neighborships, not using IGP for BGP connectivity as I have static routes.
I entered redistribute static subnets under OSPF 1 on router 4 so all OSPF routers can now ping all Lo0 of every router including R4-6 BGP routers. Would this be a good practice implementation, or is IGP usually always used on BGP routers which may connect to ISP BGP routers, etc.?
R2:
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface GigabitEthernet1/0
ip address 10.1.1.2 255.255.255.0
ip ospf message-digest-key 1 md5 cisco
ip ospf 1 area 0
negotiation auto
interface GigabitEthernet2/0
ip address 10.1.3.2 255.255.255.0
ip ospf authentication message-digest
ip ospf 1 area 1
negotiation auto
interface GigabitEthernet3/0
ip address 10.1.4.2 255.255.255.0
ip ospf 1 area 1
negotiation auto
router ospf 1
router-id 2.2.2.2
network 2.2.2.2 0.0.0.0 area 1
R4:
interface Loopback0
ip address 4.4.4.4 255.255.255.255
no ip address
shutdown
duplex half
bandwidth 128
ip address 10.1.4.4 255.255.255.0
ip ospf 1 area 1
load-interval 30
negotiation auto
ip address 11.1.3.4 255.255.255.0
negotiation auto
ip address 11.1.1.4 255.255.255.0
negotiation auto
interface GigabitEthernet4/0
no ip address
shutdown
negotiation auto
interface FastEthernet5/0
no ip address
shutdown
duplex half
interface FastEthernet6/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet6/1
no ip address
shutdown
duplex auto
speed auto
router ospf 1
router-id 4.4.4.4
redistribute bgp 4 subnets
router bgp 4
bgp log-neighbor-changes
bgp redistribute-internal
network 4.4.4.4 mask 255.255.255.255
network 11.1.1.0 mask 255.255.255.0
network 11.1.3.0 mask 255.255.255.0
redistribute ospf 1
neighbor cisco peer-group
neighbor cisco ebgp-multihop 255
neighbor cisco update-source Loopback0
neighbor cisco version 4
neighbor 5.5.5.5 remote-as 5
neighbor 5.5.5.5 peer-group cisco
neighbor 6.6.6.6 remote-as 6
neighbor 6.6.6.6 peer-group cisco
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 5.5.5.5 255.255.255.255 11.1.1.5
ip route 6.6.6.6 255.255.255.255 11.1.3.6
R5:
interface Loopback0
ip address 5.5.5.5 255.255.255.255
no ip address
shutdown
duplex half
ip address 11.1.2.5 255.255.255.0
negotiation auto
ip address 11.1.1.5 255.255.255.0
negotiation auto
ip address 12.1.1.5 255.255.255.0
ip ospf 1 area 0
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
duplex half
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router ospf 1
redistribute bgp 5 subnets
router bgp 5
network 5.5.5.5 mask 255.255.255.255
network 11.1.2.0 mask 255.255.255.0
network 12.1.1.0 mask 255.255.255.0
neighbor cisco remote-as 5
neighbor 4.4.4.4 remote-as 4
neighbor 4.4.4.4 peer-group cisco
neighbor 10.10.10.10 remote-as 5
neighbor 10.10.10.10 next-hop-self
no ip http server
ip route 4.4.4.4 255.255.255.255 11.1.1.4
ip route 6.6.6.6 255.255.255.255 11.1.2.6
you changed your original post, but just keep in mind that by default, when you redistribute BGP into any IGP,  OSPF in your case, it will not redistribute routes learned from iBGP
Hi yes sorry I realized I had to enter that redistribute static command. Yes, in real world or if I decide to make this particular lab more robust, I would use route filters for injecting BGP routes into OSPF.
This the particular way to go correct?
Would you say IGP is usually used between iBGP peers? I know most ISP will utilize MPLS.
