Routing and SD-WAN
Labels
CONFIGURAÇÃO BÁSICA - Cisco Catalyst C8000VPara este laboratório, optei por utilizar o dispositivo Cisco Catalyst C8000V, foi o único que permitiu a realização completa das configurações necessárias para o laboratório.Ao iniciar o dispositivo Cisco C...
DomingosSantosSilva_0-1794945982004.png DomingosSantosSilva_1-1794946015724.png DomingosSantosSilva_2-1794946038756.png DomingosSantosSilva_3-1794946049225.png
We have just upgraded the Control Components (vManage, vSmart and vBond) to version 20.18.4. Everything just works fine - no issues at all. But, now we would like to update our cEdge devices to version 17.18.04.0.759. After the upgrading the first on...
Hello Everyone,What is the recommended way to check RAM usage on a Cisco SD-WAN CEdge device?I would like to know how to check it through both the vManage GUI and the CEdge CLI.Device Model: C8500-12X4QCCould someone please share the relevant steps o...
Sam Caprio by • Frequent Visitor
  • 193 Views
  • 2 replies
I have few questions regarding Cisco Cloud onRamp for Multicloud deployment with Azure vWAN:Can one vWAN contain two vHubs in the same Azure region, each with its own C8000V pair (Cloud Gateway)? Is the second hub managed by Cloud onRamp, or only dis...
xshant by • Level 3
  • 256 Views
  • 2 replies
CONFIGURAÇÃO DOS CERTIFICADOS - vManage como CAPara o nosso laboratório, vamos utilizar o vManage como Autoridade Certificadora e para manipular os certificados criados. Para isso vamos precisar usar o shell e comandos para emitir as chaves e certifi...
DomingosSantosSilva_0-1794579957666.png DomingosSantosSilva_1-1794579957672.png DomingosSantosSilva_2-1794579957676.png DomingosSantosSilva_3-1794579957681.png
Hi community!I am currently in the process of designing an On-prem SD-WAN solution, where Edge devices will use the internet to communicate with Validator and Controller primarily. MPLS transports may be added in the future.Anyway, I am looking at th...
Hi All,We  IR1835 routers which are in SDWAN controller mode.Two routers are presenting an issue where they suddently only take IPV6 addresses on the Gi0/0/0 interface which results in us having to reset the router and rejoin it to vManage.Another is...
Hi,Is there any Cisco source showing configuration of feature templates for Cisco cloud hosted vSmart?For example, which interfaces to use and which IP addresses to configure, as well as other pramateres which are determined by Cisco Cloud.I know how...
iores by • Level 6
  • 232 Views
  • 1 replies
