03-28-2017 11:16 PM - edited 03-05-2019 08:16 AM
Can we configured BGP peering as per attached network scenario.
Does BGP peering works only on single IP?
Can BGP peering works with multiple IPs?
03-29-2017 12:23 AM
Bed time stories:
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/26634-bgp-toc.html?referring_site=RE&pos=4&page=http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/23675-27.html
http://docwiki.cisco.com/wiki/Border_Gateway_Protocol
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13751-23.html
03-29-2017 04:54 AM
Yes you can create the BGP peering as you are requesting, if the peers are over the same subnet and same BGP domain you also could use peer-groups and dynamic BGP peering using: bgp listen range command to reduce the configurations lines and management otherwise you can create the peering individually using neighbor commands and their attributes:
http://www.cisco.com/c/en/us/td/docs/ios/12_2sx/12_2sxh/feature/guide/sx_bdyn.html
http://www.rogerperkin.co.uk/routing-protocols/bgp/bgp-listen-range-command/
Please rate the comment if it is useful
