BGP routing
Chin
Level 2
Level 2
Hi Guys,
I have a doubt on ip route which advertise by BGP.
When I show ip route and the specified ip route not showing. Is it the subnet in the ip prefix and ip route must be tally? Wish anyone can pinpoint where was the wrong config i did.
Here is my config:
ip route 172.16.100.0 255.255.255.0 172.16.145.1
ip prefix-list ROUTE-WAN seq 5 permit 172.16.100.0/29
router bgp 60500
no synchronization
bgp log-neighbor-changes
network 172.16.0.0
timers bgp 15 20
redistribute connected
redistribute static
neighbor XX.XX.XX.XX remote-as 4747
neighbor XX.XX.XX.XX route-map BGP-WAN out
no auto-summary
route-map BGP-WAN permit 10
match ip address prefix-list ROUTE-WAN
2 Accepted Solutions
bjornarsb
Level 9
Level 9
Try changing the mask in the prefix-list to /24
hth
If the above mentioned is the case, then I have tested it and found problem with
ip route 172.16.100.0 255.255.255.0 172.16.145.1 command
if you are doing a static route for the /29 route excluding the one which is locally orginating, there would be no problem.
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
7 Replies 7
bjornarsb
Level 9
Level 9
hth
Hi Bjornarsb,
I have change the ip router to 172.168.100.0/29 and the BGP able to advertised it.
Thank you very much.
can you please share the output for
sh bgp ipv4 uni summ
sh bp ipv4 uni
You have the ip route command is in which router.
I mean do you have /29 of 172.16.100.0 is local to your router and you also have some other network other than /29 in other routers.
Thanveer
Thanveer
Hi Muhammad,
Sorry for late reply, Yup, I change the ip route
ip route 172.16.100.0 255.255.255.240 172.16.145.1 and BGP able to advertised the network segment.
Thanks for your help.
Hello, BGP considers the /24 and the /29 as totally different routes, therefor you will always need a specific match. BGP criteria for advertisement is that the exact prefix should be present in the routing table to be advertised out. And rightly suggested above the correct commands for this.
You also had 'redistribute static' - did you see the /24 being advertised out?
You wouldn't need the 'neighbor XX.XX.XX.XX route-map BGP-WAN out' command if you are redistributing your statics.
Hope this helps.
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hi Bilal Nawaz,
Thanks for your explanation. After I sorted it out the /24 to /29, it is able to advertised out.
"You wouldn't need the 'neighbor XX.XX.XX.XX route-map BGP-WAN out' command if you are redistributing your statics."
Yup, I found this command also unnecessary to put in BGP config as well.
