BGP - Routing
asifmohamamed
Visitor
I have configured a Two service provider BGP configuration in single router.
Configuration as given as below...
G_Ware#sh running-config | s route
router bgp 64515
 no synchronization
 bgp log-neighbor-changes
 network 10.103.0.0 mask 255.255.240.0
 neighbor 10.0.0.109 remote-as 10201------------------------------------SP 1
 neighbor 10.0.0.109 update-source GigabitEthernet0----------------SP 1
 neighbor 192.168.136.177 remote-as 9583-----------------------------SP 2
 neighbor 192.168.136.177 update-source FastEthernet8.162-----SP2
 no auto-summary
G_Ware#Sh ip route
Gateway of last resort is 192.168.136.177 to network 0.0.0.0
B*    0.0.0.0/0 [20/0] via 192.168.136.177, 2d01h
      10.0.0.0/8 is variably subnetted, 80 subnets, 5 masks
B        10.0.0.2/32 [20/0] via 10.0.0.109, 2d01h
B        10.0.0.28/30 [20/0] via 192.168.136.177, 06:58:42
C        10.0.0.108/30 is directly connected, GigabitEthernet0
L        10.0.0.110/32 is directly connected, GigabitEthernet0
B        10.0.0.120/30 [20/0] via 192.168.136.177, 06:58:42
B        10.180.80.0/20 [20/0] via 192.168.136.177, 2d01h
B        10.180.160.0/20 [20/0] via 192.168.136.177, 2d01h
B        10.182.0.0/20 [20/0] via 192.168.136.177, 2d01h
B        10.182.32.0/20 [20/0] via 192.168.136.177, 2d01h
B        10.184.0.0/20 [20/0] via 10.0.0.109, 2d01h-----------------My Router Learns SP2 Networks through SP1(instead of learning through SP2)
B        10.184.32.0/20 [20/0] via 192.168.136.177, 06:58:09
B        10.186.48.0/20 [20/0] via 192.168.136.177, 2d01h
How to restrict above issue and also i require my router wants to learn SP1 network via SP1 and SP2 network via SP2.
I have attached configuration of Router along with ip route status
Thanks in advance
Asif
7 Replies 7
Jon Marshall
What does a "sh ip bgp 10.184.0.0 255.255.240.0" show ?
If that subnet belongs to ISP2 then the route advertised from ISP2 should have a shorter AS path.
Jon
Find a below output after check with sh ip bgp 10.103.0.0 255.255.240.0 command....
G_Ware#sh ip bgp 10.103.0.0 255.255.240.0
BGP routing table entry for 10.103.0.0/20, version 21
Paths: (1 available, best #1, table default)
  Advertised to update-groups:
  Local
    0.0.0.0 from 0.0.0.0 (192.168.136.178)
      Origin IGP, metric 0, localpref 100, weight 32768, valid, sourced, loca
l, best
I don't understand what you have posted.
The output is for your 10.103.0.0 255.255.240.0 subnet but I thought you were asking about the subnet you highlighted in your original post ie. 10.184.0.0 255.255.240.0.
Jon
Sorry, by mistake I have posted output for 10.103.0.0 255.255.240.0
Kindly find a output 10.184.0.0 255.255.240.0
G_Ware#sh ip bgp 10.184.0.0 255.255.240.0
BGP routing table entry for 10.184.0.0/20, version 69
    10.0.0.109 from 10.0.0.109 (202.148.199.122)
      Origin IGP, localpref 100, valid, external, best
Asif
Is this an MPLS network ?
Jon
SP 1- MPLS VPN
SP 2- MPLS
According to your output you are not receiving an advertisement from ISP2 for that subnet.
Are you sure you are advertising that subnet to both ISPs at the remote site ?
What do you mean by just MPLS ?
Jon
