My router is peered to another via BGP. Pings are allowed but traceroute is not. I am trying to implement ttl security hops, but the configuration causes my peers to drop. It doesn't matter if I set the hop count from 1 to 250, same results. Is traceroute traffic required to use this feature?
已解决! 转到解答。
Hi @Adam Soukup ,
traceroute is not used or required by this feature.
Make sure you configure "neighbor x.x.x.x ttl-security" on both neighbors. If the neighbors are directly connected, you need to use "neighbor x.x.x.x ttl-security hops 1" on both sides.
The issue with running the ttl-security only on one side, is that the eBGP neighbor not configured with this feature will send a TTL of 1 by default instead of TTL of 255 when the ttl-security feature is configured. This will cause the neighbor configured with the ttl-security feature to silently drop the packets and the BGP session not to come up.
Hi @Adam Soukup ,
You are very welcome Adam.
