BGP - What is the recommended design or setup?
alexloh83
Hi folks,
Please see the attachment for the network diagram.
Sorry, I am lacking experience in BGP and now I am trying to figure out what should be the ideal and recommended design.
Hope you guys can help and advise....thanks
Scenario:
- Having two Internet Service Provider with two ASN
- Having one idenpendant IPv4 public address
- Having two Internet Cisco Router e.g. 2811
- Having two Cisco ASA Firewall e.g. 5510
Giuseppe Larosa
Hello Alex,
a good starting point is given by the following document
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080093f2c.shtml#configs
You need an iBGP session between your two border routers and a way to provide a default gateway to internal network.
One possible way is to use HSRP to provide a next-hop to the ASA pair as explained in the document above.
Another possible option is to use an IGP EIGRP or OSPF to generate a default route in the IGP from the border routers and to have it propagated via the ASA to the internal network to other network devices ( this means running the IGP also on the ASA pair).
Also consider for the BGP multihoming part the following doc that shows the various options (internet full table, only default route or default route + selected routes)
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a008009456d.shtml
Hope to help
Giuseppe
Hi Giuseppe,
Thanks for your reply, the option one look good.
I tried using GNS to simulate this and below is the configuration on my Internet Router.
I configured the ISP A and ISP B router to only propagate default route to my Internet Router (Router A & Router B)
So from my router, I only received default route.
On top of that, I configured HSRP on my router and a static route throw the independant IPv4 to Cisco ASA.
And I configured a default route from Cisco ASA to HSRP VIP.
Do you think my config correct? anything what can fine tune?
Router A
interface FastEthernet1/0
ip address 80.0.0.2 255.255.255.240
duplex auto
speed auto
standby 1 ip 80.0.0.1
standby 1 priority 110
standby 1 preempt delay minimum 60
standby 1 track Serial0
router bgp 65001
no synchronization
bgp log-neighbor-changes
network 40.0.0.0 mask 255.255.255.0
neighbor 100.1.1.1 remote-as 8001
neighbor 80.0.0.3 remote-as 65001
neighbor 80.0.0.3 next-hop-self
no auto-summary
ip route 40.0.01 255.255.255.0 80.0.0.5
RouterB
ip address 80.0.0.3 255.255.255.240
duplex auto
speed auto
standby 1 preempt
router bgp 65001
no synchronization
neighbor 200.1.1.1 remote-as 9001
neighbor 80.0.0.2 remote-as 65001
neighbor 80.0.0.2 next-hop-self
no auto-summary
ip route 40.0.0.0 255.255.255.0 80.0.0.5
Hello Alex,
your configuration template is correct.
I would just add a route-map to accept only the default route from providers on the eBGP sessions.
ip prefix-list ONLY-DEFAULT permit 0.0.0.0/0
route-map INTERNET-IN permit 10
match ip address prefix ONLY-DEFAULT
router bgp 65001
neigh route-map INTERNET-IN in
Hope to help
Giuseppe
