Configuring Cisco Router 2900 for PPPoE
I have DSL 8Mbps DL and 768kbps UL
The setup look like this:
Internet -> Modem -> Cisco Router -> Firewall -> Switch Core - > Multiple switches like sfe2000p
CiscoRouter: i use port gig0/1 for PPPoE and i use port gig0/2 for LAN static
Router port gig0/2 with 122.54.144.153/29 connected directly to Firewall port13 with 122.54.144.154/29
i want 122.54.144.153/29 will my default gateway
Please include no limit bandwidth,filter etc at router, Firewall will be DHCP Server and control the bandwidth, filtering etc and the client computer should get 8Mbps
Mode: Routing
Encapsulation: PPPoE
     Username: xx
     Password: xx
     Service Name: ISP name
Multiplexing: LLC
Virtual Circuit ID
     VPI: 0
     VCI: 100
IP Address: Static
Connection: Nailed-Up Connection
9 Replies 9
paolo bevilacqua
There are many thread  on the matter as well documentation freely available on cisco.com, including example. These will give you a starting point from you you can always come back for specific questions or problems.
All you have to do is a search for pppoe client.
i tried.. but the client computer.. cant get 8mbps..
Post config obscuring sensitive data.
Here's my initial config
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 10
interface GigabitEthernet0/2
ip address 122.54.144.153 255.255.255.248
duplex full
speed 1000
interface Dialer1
ip address negotiated
encapsulation ppp
dialer pool 10
ppp authentication pap callin
ppp pap sent-username xxxx password 7 xxxxx
ppp ipcp route default
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 122.54.144.152
ip route 0.0.0.0 0.0.0.0 Dialer1
Try
interface dialer1
mtu 1492
ip tcp mss-adjust 1452
no ip route 0.0.0.0 0.0.0.0 122.54.144.152
no ip route  0.0.0.0 0.0.0.0 dialer 1
omg.. the last time i left this config its working fine
i can ping 4.2.2.2 while im router
but now.. i cant ping 4.2.2.2 the configuration is the same nothing change i just add your
mtu 1492
there's something wrong or need to reboot/restart the hardware and configure it again..
coz i reconfigure it now by deleting interface dialer 1 and shutting down router port 1 and router port2
its still didn't work...
if i connect the modem on basic router like linksys.. it can give internet connection..it means my internet connection is active not down..
Check with "debug ppp neg" and "term mon" what happens. Sometime ISP locks to client MAC and it may take hours with the modem off to clear that.
However if your firewall supports PPPoE, and you don't want the router to perform NAT or other functions, there is no point in using the Cisco router at all.
debug ppp neg
ppp protocol negotiation debugging is on
term mon
console already monitors
however i just want to learn about cisco.. its more fun..
i'm very interested of it
i want really to learn or someone hire me without salary just to teach me how to deal with cisco world
i can deal in 2 or 3 years..
i promise on that.. but in this world people would not do that.. they prefer to have expert people
1.
mtu 1492 <-- may i know what is this.. and can i set higher number on this?
ip tcp mss-adjust 1452 <--- may i know what is this.. and can i set higher number on this to have more efficient speed
now i can ping 4.2.2.2 but
when i run speedtest to test my bandwidth it hangs
router message me this:
outbound cdp packet dropped, NCP not negotiated - what meaning of this?
