BGP with 4506e
vishalpatil86
Dear All,
We are using two ISP lines, but we dont have BGP router... Is there any way thatwe can use these lines as failover for eac other??
Vishal
5 Replies 5
Sudeep Valengattil
Hi Vishal,
Since you dont have BGP and cannot run IGP with ISP, static floating routes would be an option.  So if one ISP line goes down, it would use the other one.
Sudeep
Dear Sudeep,
Thanks for the reply.. Can you guide me through the configuraion?
Configure a default route by issuing the command "ip route 0.0.0.0 0.0.0.0 ".  AD (administrative distance) should be greater than the actual route.  For eg;
config)# ip route 0.0.0.0 0.0.0.0 10.0.12.2  <<< actual
config)# ip route 0.0.0.0 0.0.0.0 10.0.13.3 250   <<< floating route with higher AD
Sudeep
Dear Sudeep,
Can it be configured with a router of 2800 series which has two fast ethernet, one bri and two serial interfaces?
If yes, please guide me
The configuration suggested by Sudeep will work only when the first hop fails, for a more better solution please follow the below configuration suggested by Cisco :
http://www.cisco.com/en/US/docs/ios/12_4/ip_sla/configuration/guide/hsicmp.html
Manish
