Blocking traffic on ASA
BHconsultants88
Hi everyone
I hope someone can help me with this. I'm trying to restrict traffic on a Cisco ASA (config attached). I want to block all Internet browsing from the LAN (with the exception of 3 statically assigned PC's). I also want to block users from opening emails or connecting to their mail server.
Is this possible on the ASA ACL's?
Julio E. Moisa
You could use an object-group to define which IP addresses are going to be allowed to get Internet access but you need to modify to NAT, and also create the respective ACLs.
Example:
object-group network INTERNAL-NETS
network-object host 1.1.1.1
network-object host 2.2.2.2
network-object host 3.3.3.3
nat (INSIDE,OUTSIDE) source dynamic INTERNAL-NETS  interface
You could use the same object-group for the ACL, but I prefer to use other to be more flexible:
object-group network PRIVATE-NET
access-list INSIDE-IN extended permit tcp object-group PRIVATE-NET any eq 80
access-list INSIDE-IN extended permit tcp object-group PRIVATE-NET any eq 443
access-list INSIDE-IN extended permit udp object-group PRIVATE-NET any eq 53
access-list INSIDE-IN extended deny tcp object-group PRIVATE-NET any
* You can also use an object-group to collect the ports to use.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
That makes perfect sense. Thank you so much, I will try that shortly.
I'm guessing the mail aspect of it will be trickier. Or would that just be a standard ACL denying all to the mail server IP?
I think for the email, you can allow the used ports 110,465, 25, etc. as you are already filtering by IP you can open the ports and destination IP cannot be required unless you want be more specific.
