Routes advertisement issue
Not applicable
Hello -
Good Day -
Refer to the attached diagram, we are receiving some 5 prefixes from Site-A having BGP-ASN 100 -and we are advertising the same prefixes in MPLS Cloud to reach Site - B - but due to same ASN of Site-A and MPLS Cloud - these prefixes are being dropped by MPLS Cloud due to common ASN.
We do not have access to Site-A router and ASN will not change.
MPLS Cloud are not changed ASN.
Someone please guide how to figure out with this issue - MPLS Carrier has confirmed AS-Overide is already in place -
Tried following:
R4 (as 100) R5 (as100)
R4 (as 100) R5 (as 500)
19 Replies 19
cofee
Level 5
Level 5
MPLS Carrier has confirmed AS-Overide is already in place - Then why is it not working?
You may find this link useful:
https://supportforums.cisco.com/discussion/12197686/bgp-asn-path-issue
Is confirmed the as-override under the address-family related to the VRF?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Yes - AS-Overide was under address-family ipv4 vrf.
Thank you
Is possible to know the configuration on the CE routers?
Thank you.
Thank you for your writing!
Please find below relevant Configurations also attached fine topology along with router Labels which I missed in last release.
In attached topology - RTR-1 is receiving some 5 Prefixes from its neighbor (Site-A) and objective is these Prefixes should be see by RTR-3 - the challenge I am facing is Site-A and MPLS Cloud has same ASN (AS-100) due to this MPLS could sees its own ASN with Prefixes and not advertising to RTR-3 - My carrier has confirmed AS-Overide is already in place but when this never with AS-Overide then I tried the same topology in GNS which give the same result and Prefixes not traversing over MPLS Cloud -
Hope above details and attached topology is sufficient to understand -
RTR-1
ip vrf BGP
 rd 1:1
 import ipv4 unicast map PREFIX-LIST
 route-target export 1:1
 route-target import 1:1
interface Loopback99
 ip vrf forwarding BGP
 ip address 10.72.255.237 255.255.255.255
router bgp 200
 bgp log-neighbor-changes
 neighbor 172.16.1.1 remote-as 300
 address-family ipv4
  neighbor 172.16.1.1  activate
  neighbor 172.16.1.1  prefix-list PREFIX-LIST in
  auto-summary
 exit-address-family
 address-family ipv4 vrf BGP
  neighbor 172.16.1.1  remote-as 65000
  neighbor 172.16.1.1  ebgp-multihop 3
  neighbor 172.16.1.1  as-override
 exit-address-family
ip prefix-list PREFIX-LIST seq 5 permit 1.1.1.1/32
ip prefix-list PREFIX-LIST seq 15 permit 2.2.2.2/32
ip prefix-list PREFIX-LIST seq 25 permit 3.3.3.3/32
ip prefix-list PREFIX-LIST seq 30 permit 4.4.4.4/32
ip prefix-list PREFIX-LIST seq 35 permit 5.5.5.5/32
RTR-2
router bgp 300
  neighbor 172.16.1.2 remote-as 65200
 neighbor 172.16.1.2 ebgp-multihop 255
 neighbor 172.16.1.2 update-source Loopback99
 neighbor 172.16.1.2 next-hop-self
 neighbor 172.16.1.2 soft-reconfiguration inbound
 neighbor <MPLS Cloud Peer IP> remote-as 100
sh ip bgp
     Network          Next Hop            Metric LocPrf Weight Path
 *>  1.1.1.1/32  10.72.255.237                          0 200  100 i
 *>  2.2.2.2/32  10.72.255.237                          0 200  100 i
 *>  3.3.3.3/32  10.72.255.237                          0 200  100 i
 *>  4.4.4.4/32  10.72.255.237                          0 200  100 i
 *>  5.5.5.5/32  10.72.255.237                          0 200  100 i
Please look at the gns3 file I sent. You mentioned you simulated your topology and that didn't work for you. Did you use gns3, if so can you share the config. file I want to take a look at it.
Not applicable
yes - I saw that gns-3 file that you sent.
I can paste my configs but my topology contains over 21 routers and switches and several other things are running on it - which leads to confusion so refer the config I pasted above -
Not applicable
Yes - MPLS carrier has confirmed AS-Overide is in place but this didn't fixed the issue - in order to figure-out this , I simulated scenario in GNS - and created MPLS Cloud in below topology -
RTR-1 (ASN-100) >>> RTR-2 (ASN-300) PE (ASN-100) ---- P ---- PE (ASN-100) >>> RTR-3-(ASN-300)
I enabled AS-Overide on both PE neighbors towards RTR routers but prefixes on RTR-2 having ASN 100 didn't reach to RTR-3 - i don't know what went wrong - but i tried another solution mentioned below but that didnt worked -
on RTR-2 I created VRF named BGP and enabled AS-Overide under  address-family ipv4 vrf BGP but when I see bgp routes on RTR-2 I saw ASN-100 still seen with prefixes -
I will refer link you shared - however do you any any more idea in order to fix that trouble ?
I was able to make it work using below configuration:
router bgp 100
neighbor x.x.x.x allowas-in
R4#sh ip bgp
BGP table version is 6, local router ID is 30.30.30.4
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, x best-external, f RT-Filter
Origin codes: i - IGP, e - EGP, ? - incomplete
*> 1.1.1.1/32       30.30.30.3                             0 300 200 100 i
*> 2.2.2.2/32       30.30.30.3                             0 300 200 100 i
*> 3.3.3.3/32       30.30.30.3                             0 300 200 100 i
*> 4.4.4.4/32       30.30.30.3                             0 300 200 100 i
*> 5.5.5.5/32       30.30.30.3                             0 300 200 100 i
Not applicable
In the topology in which router and neighbour you have configured "Allowas-in" - i tried will all the combination but never works - though i still see prefixes has AS-100 - so what happend last router RTR-3 did not receive all thoses prefixes having AS-100 tagged -
I dont have a problem in receiving prefixes on RTR-2 from RTR-1 - the problem occurs when I am trying to see the prefixes on RTR-3 that are learned from RTR-1 - the cause is MPLS cloud has the same ASN that RTR-1 has so PE router is not advertising all those prefixes which comes with AS-100 - that is an normal behaviour in BGP i-e AS PATH loop detection.
But i'd like to see how you made this work? Let me know if you are able to see Prefixes on RTR-3 from ASN-100.
Regards.
Can you tell me who is router 3 in your topology? I don't see any names. Are you addressing router at site b as router 3?
Not applicable
Please see attached - RTR-3 is Router -3
Attached is the working gns3 topology. Please let me know if you have any questions.
I removed the previous attachment, it was having some issues. I hope this one will work for you if you have the new image.
Not applicable
Thank You for your Working and sharing simulation -
You topology is different then mine and there shouldn't be any issue since both are edge routers I am R-1 and R-4 are on same ASN but all middle routers are on different AS -and you Allowas-in should work -
In my Scenario -
Your R4 is "MPLS Cloud" and "MPLS Cloud" need to send all Prefixes that are received from Router-1 with ASN-100 to the adjacent router let say Router-5. and MPLS Cloud and Router-1 has same ASN -100.
If you could revise your topology and add one more router -5 and modify as stated above and see if this works for you.
