Bond 2 T1 interface
nilesh276
How to bond to T1 ? Besides Mux any other way we can bond 2 T1 lines works line one pipe.
7 Replies 7
Richard Burts
Nilesh
multilink ppp is a very effective alternative for bonding 2 T1s so that they act like one pipe.
The basics of configuring it would look something like this:
interface Multilink1
ip address X.X.X.X 255.255.255.252
ppp multilink
multilink-group 1
interface Serial0/0
no ip address
encapsulation ppp
ppp multilink
multilink-group 1
interface Serial0/1
no ip address
encapsulation ppp
ppp multilink
multilink-group 1
Note that the IP address (and any other layer 3 configuration) goes on the multilink interface and there is no IP address or any other layer 3 information on the serial interfaces.
Rick
Rick
Hi Rick,
Thanks for reply. I know that but I think that feature designed for ISDN do you think its also works for T1 leased line very well...........I am not sure thats why !!!
Nilesh
I have done multilink on T1 circuits and it works very well.
Rick
Rick
Does it works for 2 private T1 lines or also good for 2 T1 Internet lines? Suppose I have 2 T1 from same ISP & 2 T1 from different ISP same for Private line ??
Nilesh
I do not believe that it makes any difference whether the T1s are private lines or Internet lines. It should work fine for either.
I have never done multilink on lines from different providers so I can not speak from experience about this. There has been some discussion suggesting that the different latencies possible when lines are from different providers could create performance problems with multilink. I do not believe that anyone has had a definitive answer about this.
Rick
Rick
Not only for T1, there is people using MLPPP for OC-12 lines using specialized cards on big switches !!!
Will this work for 2 LES circuits as well.
