Bonding 2 T1s running Frame Relay
Hieu Cao
Level 4
Level 4
Our internet T1 is almost maxed out, and we're looking into adding another T1 from a different carrier. Is it possible to bind 2 T1s running Frame Relay, encapsulation HDLC and terminated in the same router?
Thanks.
9 Replies 9
paolo bevilacqua
Do you use the T1 for internet? There is bonding to do, you will just have a second ISP and can send some destination off one T1 or balance equally on both. That requires that you run NAT on the router itself.
Thank you for your response.
Yes, we've a T1 used for Internet. Is it possible that you can explain it in more detailed as I am not quite clear what you're referring to.
Originally, I thought that I would need to use MPPP or BGP to bind the T1s together. But I don't think that MPPP would work since I am running FR, encapsulation HDLC.
Thanks for your time and input.
hieu
Since they are 2 providers, then you can't bond the T1s anyway, you'll have to then do load sharing or balancing between the 2 links.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Thanks, Mohammed. Silly question to ask..but What protocol should I be using to do load-sharing between the 2 T1s from 2 different ISPs?
If the 2nd T1 is coming from the same ISP, what should I use to bind the 2 T1s?
Thanks for your time.
hieu
Load sharing shall be done in layer 3 (routing wise), in the case of 2 ISPs.
If both T1s were from the same ISP you can do MPPP to bond them.
Mohammed Mahmoud.
Thank you all for your reponse.
hieu
Thank you but mine was a confusing answer.I wrote "there is bonding to do" when in fact I meant to say the opposite.
Will write slower next time.
If both FR link will reside on the same router you can use multilink FR Multilink Frame Relay (FRF.16) so the load sharing can be take place on layer2. Here is a link to see how it works:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1829/products_feature_guide09186a0080087079.html
Or if your provider do not support it than the "old fashioned" layer3 load balancing is your choice.
Please rate if helps
Kriszti?n
Hello Krisztian,
Thank you very much for the input and the link. It's very helpful.
hieu
