Bonding T1s together??
mccmhtac1
I have to bond 3 T1s between a Cisco 2620 router and a Cisco 6509 (MSFC w/ FlexWan Module).
At another site I have to bond 2 T1s to the same 6509.
Any assistance will be helpful.
ajay chauhan
Level 7
Level 7
configuration of multilink should look like this.
controller T1 0/0/0
 framing esf
 linecode b8zs
 channel-group 0 timeslots 1-24
controller T1 0/0/1
 framing esf
 linecode b8zs
controller T1 0/1/0
 framing esf
 linecode b8zs
controller T1 0/1/1
 framing esf
 linecode b8zs
interface Multilink1
 ip address 1.1.1.1 255.255.255.252
 no cdp enable
 ppp multilink
 ppp multilink group 1
interface Serial0/0/0:0
 no ip address
 encapsulation ppp
 no fair-queue
 ppp multilink
interface Serial0/0/1:0
 no ip address
 encapsulation ppp
 no fair-queue
 ppp multilink
interface Serial0/1/0:0
 no ip address
 encapsulation ppp
 no fair-queue
 ppp multilink
interface Serial0/1/1:0
 no ip address
 encapsulation ppp
 no fair-queue
 ppp multilink
Router# show ppp multilink
Multilink1, bundle name is MY-ISP
  Endpoint discriminator is MY-ISP
  Bundle up for 10w0d, total bandwidth 6144, load 25/255
  Receive buffer limit 48000 bytes, frag timeout 1000 ms
    2/3020 fragments/bytes in reassembly list
    204716 lost fragments, 310561297 reordered
    474999/517174257 discarded fragments/bytes, 474999 lost received
    0x256CD0 received sequence, 0x2071C9 sent sequence
  Member links: 4 active, 0 inactive (max not set, min not set)
    Se0/1/1:0, since 10w0d
    Se0/1/0:0, since 10w0d
    Se0/0/0:0, since 10w0d
    Se0/0/1:0, since 10w0d
No inactive multilink interfaces
Router#
is this config for the 6509? I am confused with the controllers
Multiple are basically formed for serial links when we configure controller for T1 and this would be the config.
