01-23-2006 12:02 PM - edited 03-03-2019 11:32 AM
Admittedly my question is not only subjective but your answers may also differ based on your specific network's use... but here goes:
In the past our network has just relied on the IP Firewall Feature Set of Cisco IOS. We now have a PIX 515e pair that will providing us with security, located just behind the border routers. Now that we are going to be using the PIX pair I would imagine we can safely reduce the number of ACL entries on the routers.
Web hosting and server hosting is primarily what we do - primarily http, smtp, pop3, dns and a few others is pretty much all we need. Unfortunately our current ACL has some specific entries related to clients' servers, etc, that it isn't as easy as just allowing a handful or ports and deny everything else. I think we are probably going to need to deny a handful of protcols/ip-blocks and allow everything else in (and then let the PIX pair to their work.)
What services should I explicitly block by default? What net blocks such as 10.0.0.0, 172.16.0.0, 192.168.0.0 should I block? How about Unicast Reverse Path Forwarding (we will be running BGP so I guess I'll need loose mode)? Denying our own block(s) back in.... Any other "obvious" items I should address?
I'm so used to the main external interface on these routers having a heavy ACL applied to them that it is a strange concept opening them up. I could obviously just keep my existing ACL for a while but I'd rather let the PIXs do that work. Thanks for any advice,
Hutch
01-23-2006 02:05 PM
Hi Hutch,
A great starting point is the Secure IOS Template produced by the maintainers of the BOGONs list:
http://www.cymru.com/Documents/secure-ios-template.html
It has a number of IOS security features built in as well as ACLs that block bogons...
Hope that helps - pls rate the post if it does.
01-23-2006 05:00 PM
Thanks for the link - I felt a little foolish posting that (very subjective) question, but this is a great start for me. Exactly what I was looking for.
Hutch
02-14-2007 08:21 AM
Why would you route the bogons to null0 if you have them denied in a ACL already? Should you do both or one or the other? The only reason I can think of is to save on latency because the packet will not be handled by the ACL and would be routed to a black whole directly in with no way out. Could there be any issues with BGP?
Matthew
02-20-2007 07:30 AM
The ACL is for outside host while the Null is for inside host.
