Bought new Router need Help for Beginner
datadyne112
                   Hi i am new here
Yesterday i Received new router 897VAW-E-K9 need help for newbie in cisco how to configure in first time and how to enable web GU.I
if  steps one by one it well be Grateful...
and thanks
2 Accepted Solutions
Islam Nadim
Hello Mohammad,
First, you need console access as to enable the GUI for it.
When you connect to the console, just paste the commands below as to enable the GUI (NOTE: To access the GUI, you'll need to have an ethernet cable connected to the router) .. I will show you just basic config to access the GUI without any security measures in place. If you need advanced config, you can ask
If you see this message when you connect with the console, just type no
Continue with configuration dialog? [yes/no]:
enable
configure terminal
line console 0
password cisco ! This password will be used when accessing through the Console connection.
login local
exit
username name privilege 15 passowrd 0 password ! Replace name with the username you will use, and password with the password for that username
interface FastEthernet0/0 ! The interface you will connect to with the LAN Cable
ip address 10.10.10.1 255.255.255.0 ! This is a temp IP just for management access and configuration, can be changed later
no shutdown
ip http server
ip http secure-server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 1000
line vty 0 4
privilege 15
login local
transport input all
transport output all
end
Now on your PC, go to the LAN Interface settings and assign a static IP as to be able to be in the same subnet with the router. You can use the configuration below for your PC:
IP Address: 10.10.10.2
Subnet Mask: 255.255.255.0
Default Gateway: 10.10.10.1
Finally, if you don't have CCP (Cisco Configuration Professional) or ASDM (Adaptive Security Device Manger) download any of them (CCP Recommended).. Then use it to connect to the router. You'll find tons of tutorials for the CCP online.
Hope I helped.
Best Regards,
Islam M. Nadim.
You can't assignan IP to a layer 2 port.You must configure a vlan interface and assign the IP address to it.
int vlan 1
Alain
11 Replies 11
Islam Nadim
Hello Mohammad,
enable
configure terminal
line console 0
login local
exit
no shutdown
ip http server
line vty 0 4
privilege 15
login local
transport input all
end
Hope I helped.
Best Regards,
Islam M. Nadim.
Islam, is right..the key commands to enable GUI access of router are below as mentioned by Islam...
ip http server
You suppose to use first two commands to achieve this.
Hope it helps...
Amit
Thank you Amit for clarifying more
Hi Islam
thank you thank you very much srry for late responce i was busy in two days
i followed ur instrruction step by step i stuck in assighn ip command alawys faild it show like this :
Router>en
Router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#line console 0
Router(config-line)#password cisco !
Router(config-line)#login local
Router(config-line)#exit
Router(config)#username example privilege 15 password 0 example !
Router(config)#interface fastethernet0/0 !
% Invalid input detected at '^' marker.
___________________________________________
i search in google most of sites and article they said u must know port name or number and i follow the articles to know
port name it show me like this :
Router#sh int status
Port    Name               Status       Vlan            Duplex Speed Type
Gi0                        notconnect      1            auto    auto 10/100BaseTX
Gi1                        notconnect      1            auto    auto 10/100BaseTX
Gi2                        notconnect      1            auto    auto 10/100BaseTX
Gi3                        notconnect      1            auto    auto 10/100BaseTX
Gi4                        notconnect      1            auto    auto 10/100BaseTX
Gi5                        notconnect      1            auto    auto 10/100BaseTX
Gi6                        notconnect      1            auto    auto 10/100BaseTX
Gi7                        notconnect      1            auto    auto 10/100BaseTX
Wl8                        connected      1            auto    auto 10/100BaseTX
there is no fastethernet like u metntion in commands !
any tips
ooh i forget when i assighn port to gi0 gigaethernet and i try to complete the commands show me like this :
Router(config)#interface gi0
Router(config-if)#ip address 10.10.10.1 255.255.255.0
% IP addresses may not be configured on L2 links.
and  thanks
Message was edited by: Mohammad Al-baker
Hello Mohammad,
I've sent you a message .. I need to do a live test with you .. Kindly check the message and tell me.
Best Regards,
Islam M. Nadim
int vlan 1
Alain
Hello cadet alain,
I beg to differ, since it is stated that the device is a router, then you can assign an IP to the port, but you have to inform the router to change it to a layer 3 then configure an IP Address .. However, it should be enabled by default.
thnks candit for information ,
in my device 7 ports 0-7 in Gigaethernet and 8 in WAN  can i assighn Vlan in any Gigaethernet Ports if it possible any
basic command for it.
and thanks
Hello Mohammad,
     As we checked during the live session, just use interface GigabitEthernet8 as your uplink interface .. It can be configured with an IP Address directly .. Also, don't forget to save the configuration by issuing the command "write" (Without the quotes) from the enable mode not the config mode.
Best Regards,
Islam M. Nadim
Hi Islam,
I beg to differ too.
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/hardware/installation/guide/1Overview880-860.html#wp1227500
As you can see these are 8 switchports so layer 2 so you can't assign an IP to them.
you connect your LAN hosts to these ports and then configure a SVI for this vlan(by default vlan 1) and give it an IP address.
The Gigabit WAN interface is for connecting to another router or do PPPoE.
Alain
Thanks it works thank u 4 ur support after live session i forgot to run command 'write' to save configuration i  follow ur first instrucrion just change the interface line from fastethernet0/0 to gi8 and run CCP it Detect my device after solve half display issue but  there is problem when i navigate in configure and monitor Tabs, click in any sub options it hangs or stuck in loading java maybe the new ver of java not work correctly any solution for this problem.
