New Cisco 887 routing question
gateway03
    I'm new to cisco 887 routers, I seem to have successfully setup dhcp and can connect to it with a workstation.
The 887 can ping internet hosts and telnet to internet hosts but the dhcp workstations cannot.
Can some please help me see my mistake.
Thank you
Robert
Layout
10.10.10.0  Vlan1 FE1,2,3  to Vlan10 208.23.6.130 to FE0  Routes to 208.23.6.1 Internet router( internet )
My config follows:
version 15.0
no service pad
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-330327606
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-330327606
revocation-check none
rsakeypair TP-self-signed-330327606
crypto pki certificate chain TP-self-signed-330327606
certificate self-signed 01 nvram:IOS-Self-Sig#4.cer
ip source-route
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
   import all
   network 10.10.10.0 255.255.255.248
   default-router 10.10.10.1
   lease 0 2
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
license udi pid CISCO887-K9 sn FTX151601PN
vtp mode transparent
username name privilege 15 secret 5 $1$o49Z$KzpiJQjgR5VYyTP2ADUKY.
vlan 10
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
no atm ilmi-keepalive
interface FastEthernet0
switchport access vlan 10
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Vlan10
description Public Internet
ip address 208.23.6.130 255.255.0.0
ip nat outside
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list NAT interface Vlan10 overload
ip route 0.0.0.0 0.0.0.0 208.23.6.1
ip route 10.10.10.0 255.255.255.248 208.23.6.1
access-list 23 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
Collin Clark
I see a couple of things. The first is that your NAT statement calls the access list named NAT, but the ACL does not exist.
ip access-list standard NAT
Second, you should remove this statement
Third, you'll want to add some DNS servers in your DHCP pool. A couple of public ones are 4.2.2.1, 4.2.2.2, 8.8.8.8
Hope it helps.
Rob,
Please do the following:
1-  ip dhcp pool ccp-pool
   import all
   dns-server 8.8.8.8 8.8.4.4
   lease 0 2
2- Romove ip route 10.10.10.0 255.255.255.248 208.23.6.1
3- ip route 0.0.0.0 0.0.0.0 vlan10
4- change 'ip nat inside source list NAT interface Vlan10 overload' to 'ip nat inside source list 23interface Vlan10 overload'
