BRI/PRI connected to a console port
beckerola
I just opened a similar thread in another section but there's still no answer (only 1) and this is somewhat urgent.
I would like to know if it's possible to connect a BRI or PRI serial interace to a console port to raise up an async line.
I already know that there are various possibilities when we use Aux ports like connect serial ports to it. Can this be done using something like "modem inout" or "modem enable" in the console line?
We are going to use Cisco 4000 and 2500 and by the moment we can't buy more async port modules, so this could be a solution, if supported.
Thank you all
beckerola
I was wondering, is it suitable to configure an asynchronous interface (associated with the BRI/PRI port) to virtually create lines pointing to the console port? sorry if i said something silly but i'm looking to all the chances.
