Trying to understand ISDN line
saravanen.g
Hi guys,
I have a 2MB PRI ISDN at my office. When i check the interface status, it shows the serial1/0:15 is always UP. Is that normal?
I've attached the output here.
Thanks.
2 Accepted Solutions
Richard Burts
saravanen
Yes this is normal. serial1/0.15 is the signaling channel used by the router and the phone company switch to communicate with each other and send signaling and control information. It should always be up.
Rick
Rick
s-sheffield
for E1 lines (the one you have) serialx/x:15
is the D channel as already mentioned in the other response.
For T1 lines (1.54Mb) its serialx/x:23 for the D channel.
HTH too
Stu
Richard Burts
saravanen
Rick
Rick
s-sheffield
HTH too
Stu
rahul0904
saravanen said it correctly.
Serial1/0:15 is signaling channel that is used by the router & the switch at telephone company to communicate with each other by sending signaling & control information. All other channels will come up as and when you connect to other ISDN.
