11-09-2020 01:38 PM
I am trying to configure an 887VA to act as a bridge for my ADSL connection and to run the dialer on a router of some sort but for now I am dialing from my laptop to test but having no success whatsoever. Can someone please point me in the right direction? I do get an error 651 when dialing up from Windows (from 2 different laptops) but just wanted a sanity check on my config first. Also the Ethernet 0 interface currently shows as down on the Cisco.
version 15.7
no service pad
hostname xxx
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authorization console
aaa session-id common
memory-size iomem 10
no ip routing
ip domain name xxx
no ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn FCZ1548C4CT
username xxx privilege 15 password 7 xxx
controller VDSL 0
interface Ethernet0
no ip address
bridge-group 1
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
bridge-group 1
pvc 0/38
encapsulation aal5snap
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 192.168.1.10 255.255.255.0
no ip route-cache
ip forward-protocol nd
no ip http server
no ip http secure-server
bridge 1 protocol ieee
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
transport input ssh
end
11-09-2020 01:51 PM
Not sure who is the provider here? is this ethernet delivery?
here is an example of a bridge group to work :
https://danjmcintyre.com/2014/03/09/cisco-887va-vdsl-ethernet-bridge-on-sky-fibre-unlimited-pro/
11-09-2020 02:01 PM
ISP is the Post Office
11-09-2020 02:08 PM
Please provide more information, how is the delivery to you ?Ethernet, what information they provided to setup, some provider as you to setup encap with vlan
11-09-2020 02:14 PM
This is a home user ADSL service. They have provided their own router but I would like to replace this with the 887VA. Unfortunately there is not much information about the service itself
11-11-2020 04:37 AM
I put the ISP provided router into bridge mode and then dialed in from my laptop which connected fine so this is likely a configuration issue on the Cisco device. I will do some more tinkering of the config to see if I can get it to work
