Bridge Group on Routers
Elie El Amil
Kindly note that I have the following scenario and I need to configure a bridge group on the two routers:
Head Office: LAN: 192.168.5.0
             WAN: 10.10.10.1
Branch: LAN : 192.168.7.0
        WAN: 10.10.10.2
Noting that I want to add a DHCP server on the Branch LAN with the same IP of the Head Office LAN.
How can I configure the bridge group on the two routers?
Is there any possibility to create a VLANs on the Branch site?
Attached you will find the network Topology.
Thanks in advance.
paolo bevilacqua
Do not use bridging because that will only cause you problems.
Use routing as everybody else, and everything will work good and smooth.
Please note that i have the subnet 192.168.5.0 in head office and i need to put a server in the branch site with the same IP of the subnet of Head Office, so how can i do a routing on the same subnet?
You don't. In the branch office, put a server with the IP of the branch.
