04-10-2023 09:50 AM - edited 04-10-2023 09:59 AM
Hello, I have a Cisco ISR4331 that is being used to route traffic from my ISP to my firewalls. I am looking to use Gig0/0/1 and Gig0/0/2 for my firewall's WAN connections, and they are redundant firewalls. Would the best configuration for this be something like
interface Gig0/0/1
service instance 399 ethernet
encapsulation dot1q 399
rewrite ingress tag pop 1 symmetric
bridge-domain 399
interface Gig0/0/2
bridge-domain 399
interface BDI399
ip address X.X.X.X 255.255.255.248
no shut
Am I leaving anything out that should be tweaked or is there a better way of doing this, aside from buying a switch module?
04-10-2023 10:20 AM - edited 04-11-2023 07:54 AM
you run ISR4331 with IOS-XE not IOS
so no need any ieee protocol
but the interface connect to router effect the solution
SW or FW it same
Case1
SW1-ISR4k-SW2
if both SW1/2 use router ports as show below
interface FastEthernet0/1
no switchport
ip address x.x.x.0
then the ISR config will be
interface GigabitEthernet1/2/3
no ip address
negotiation auto
cdp enable
service instance 100 ethernet
encapsulation untagged
bridge-domain 100
interface to SW1 and to SW2
no ip address
negotiation auto
cdp enable
bridge-domain 100
interface BDI100
ip address x.x.x.1 255.255.255.0
case2
SW1-ISR4k-SW2
if both SW use VLAN to connect to ISR as show below
switchport mode trunk
interface Vlan100
ip address 10.1.1.1 255.255.255.0
no ip address
negotiation auto
cdp enable
encapsulation dot1q 100
bridge-domain 100
that it. Freind check and update me
04-10-2023 11:19 AM
rewrite ingress tag pop 1 symmetric <<- do you have more VLAN to pass ? if not i would suggest to use simple config with below mentioned cisco example guide:
Sure that should work as expected, make sure you have the latest stable code upgrade in case of any issues:
below document explains you :
04-10-2023 12:24 PM
is ast equivalent to ieee spanning-tree protocol? It seems IEEE is not supported on my version of IOS or I am missing something.
(config)#bridge 1 protocol ?
ast IBM protocol
dec DEC protocol
ibm IBM protocol
vlan-bridge vlan-bridge protocol
04-10-2023 02:21 PM
can you post show version from -ISR4331
04-10-2023 12:54 PM
which firewalls (brand/type/model) do you have ? Can you post a schematic drawing of your (desired) topology ?
