brom> boot on 2960XR switch
ewood2624
Level 5
Level 5
We received a new 2960XR switch and on initial boot it goes into brom> mode.
CPU rev: B
Image passed digital signature verification
Board rev: 6
Testing DataBus...
***ERR -- Data bit 3: Expected = 0xfffffff7, Actual = 0xfffffff3, at addr 0x00000000.
Going to MayDay...
Xmodem file system is available.
flash probe successful
create ifs brom
create ifs bs
brom>
Is this the same as ROMMON mode?  I can't find too much out there on brom> mode.
Leo Laohoo
Nope.  This process happens before ROMmon.
This means your appliance is dead.  You may need to contact Cisco TAC and arrange for a replacement.
6 Replies 6
Leo Laohoo
Arnoldo
I have the same problem, as I've fixed?
this is what it shows:
reset
Are you sure you want to reset the system (y/n)?y
System resetting...
CPU rev: B
Board rev: 5
Testing DataBus...
***ERR -- Data bit 0: Expected = 0xfffffffe, Actual = 0xfffe, at addr 0x00000000.
Going to MayDay...
create ifs brom
create ifs bs
brom>
CPU rev: B
Board rev: 5
Testing DataBus...
Testing AddressBus...
Testing Memory from 0x00000000 to 0x1fffffff...-
***ERR -- Memory test failed
Expected = 0x44454647, Actual = 0xc4c5c6c7 at address 0x00001100
Going to MayDay...
create ifs brom
create ifs bs
brom>
Kindly  help me?
sonjubaba56@gmail.com
Hi All,
One of my customer is facing the same issue.
Any one having a solution to boot into rommon mode or normal mode from brom mode?
Disconnect power cable from ur switch then remove power module from the switch for 2-3 minutes. Reconnect then see.
Good day
fabivian
Hi, Community,
I have the same problem but the equipment doesn't have support, what do you recommend?
