Bundled T1
wgranada1
Hi all...quick question for you where can I read up on what I need to do to as far as equipment and configuration goes to connect a bundled T1?
Giuseppe Larosa
Hello Warren,
you would need two or more T1 interfaces with working links to the remote router: all the links are between the same two devices.
Then you need to use:
a) PPP multilink
http://www.cisco.com/en/US/docs/ios/dial/configuration/guide/dia_media-ind_multi_ppp.html
or
b) FR multilink FRF.16
http://www.cisco.com/en/US/docs/ios/wan/configuration/guide/wan_ml_fr_frf161_ps6441_TSD_Products_Configuration_Guide_Chapter.html
the first is more widely supported the second one is more recent.
Hope to help
Giuseppe
