C1111-4LTE IOS downgrade and License requirements
I have two questions with this particular device.
1. Can i downgrade directly from 17.6 to 16.9.x? If so what are the requirements.
2. For me to support DMNR, do i need to have appx license?
Your answers will be greatly appreciated
5 Replies 5
balaji.bandi
- yes possible but ROMMON downgrade not possible  - downgrading to 16.9.x read the release notes and downgrade steps
For me to support DMNR, do i need to have appx license? you mean DMNR  dynamic mobile network configuration
you want to connect or offer ?
BB
Hi Balaj,
Would you be able to share the downgrade steps? wasnt able to see that on the release notes. Also, upon checking the recommended rommon for 16.9.x is 16.9(1r), does that mean it only supported on that rommon version?
Yes, i mean dynamic mobile network configuration. Ill be configuring it on the 1111-4lte router. The PWG is already setup so i need to connect to it via my provider
when you downgrade from 17.X to lower, the ROMMON stay 17.3.X i dont remember exact, that does not matter for the IOS XE downgrade 16.9.X (not sure what is the reason for downgrade here)
downgrade depends on the INSTALL Mode  or Bundle Mode
if bundle is easy change the boot variable to old and reboot.
as per i know ipservice license should work for you.
BB
i need to downgrade since i dont have a cisco smart account to support smart licensing, so i need to switch back to traditional licensing
for what i know there is no option for ipservices license for c1000 series routers
16.9.X onwards everything smart License, may be lower version you can downgrade.
for what i know there is no option for ipservices license for c1000 series routers  - i mean security License.
more information check feature navigator :
https://cfnng.cisco.com/
BB
