C1941/C2901 AC Power Supply replacement
jpulliam867
We have a 1941 router in place and in production, when I would like to replace the power supply from 'C1941/C2901 AC Power Supply" to the "PWR-1941-POE=" to enable POE on the existing "4 Port GE POE EHWIC- 'EHWIC-4ESG-P"  module.
I would like to do this in the field over the weekend, Is there documentation out there on the power supply replacement procedures?
My current software ver. is Version 15.1(4)M3, RELEASE SOFTWARE (fc1) and I would like to know if support for the hardware change is covered in this release?
Thank you.
6 Replies 6
Reza Sharifi
Have a look at table-7 in this link.
Minimum Cisco IOS Software Release 15.1(2)T for  Cisco 1900, 2900, and 3900 Series routers: IP Base License of the  Universal image
http://www.cisco.com/en/US/prod/collateral/routers/ps10536/data_sheet_c78-612808.html
You have 12.2(4)M3, you should be good to go.
Reza,
Thanks so much!
Hi Jerome,
If the response was helpful, please rate and close the treat, so others can benefit from it.
Ivan Shirshin
Hi Jerome,
Please see the following step-by-step guides on replacing/installing power supples and PoE on ISR routers.
C1941:
1. Installing and Removing a Power Supply
http://www.cisco.com/en/US/docs/routers/access/1900/hardware/installation/guide/Inst_Upgr_Int_Mods.html#wp1054462
2. Installing Power over Ethernet
http://www.cisco.com/en/US/docs/routers/access/1900/hardware/installation/guide/Inst_Upgr_Int_Mods.html#wp1061465
SW is sufficient for EHWIC-4ESG-P, as Reza advised.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Ivan,
Thank you! This replacement documentation is perfect.
cheers
Welcome, Jerome!
PS: Could you also mark this as answered/resolved, please, so that others could also benefit from it later?
edited by: Ivan
Kind Regards,
Ivan
