C2811/2921 EtherChannel & Huawei switch
Hello
reference paper:
https://www.cisco.com/c/dam/en/us/products/collateral/routers/3800-series-integrated-services-routers-isr/prod_white_paper0900aecd806f698a.pdf
In my case I need to connect C2811/C2921 in Cross-Stack EtherChannel to a stack of Huawei switches.
C2811/C2921 require manual EtherChannel without LACP...
Being EtherChannel on C2811/C2921 manual, to which extent can I assume that the feature is transparent and so would work as expected in conjunction with Huawei switch stack?
Fred
5 Replies 5
Jaderson Pessoa
Hello
I suggest to you use a LACP to establish a etherchannel connection. Because in wrong settings, you network wont has problem.
For LACP on huawei, check it: https://support.huawei.com/enterprise/en/doc/EDOC1000178168/7abaffd5/link-aggregation-configuration
For LACP on cisco, check it: https://www.cisco.com/c/en/us/td/docs/ios/12_2sb/feature/guide/gigeth.html
Jaderson Pessoa
*** Rate All Helpful Responses ***
Hi Jaderson
Thanks for your reply especially for the Huawei link!
balaji.bandi
sample config should work (test and advise).
Cisco
interface Port-channel9
switchport
interface GigabitEthernet1/1
switchport
switchport mode trunk
channel-protocol lacp
channel-group 9 mode active
interface GigabitEthernet1/2
switchport
Huawei
interface Eth-Trunk9
port link-type trunk
port trunk allow-pass vlan all
mode lacp-static
interface GigabitEthernet0/0/1
eth-trunk 9
interface GigabitEthernet0/0/2
eth-trunk 9
No shutdown bot the sides and test.
BB
Thanks Balaji!!!
Hello Fred
if these suggestions assited you in resolving your problem please mark them accordingly and as solved - this would possibly assist other in the future with a similar problem
Kind Regards
Paul
