c2921 router uncommanded icmp packets transmitted
bryantsteve
C2921 router interface  with no routing protocols (using only static routes)  has ipv6 configured,  no IP redirects and no IP unreachables,  globally vstack is disabled,  IOS version 15.5(3)M8,   interface is sending out icmp packets, I can't determine how or why the router is behaving this way, does anyone have an idea why this would be happening and what action I can take to stop it. Thanks
HI,
The  ICMP type 11 code 0 is TTL Expire packet and code 0 may be received from a gateway. If it is in less amount of traffic then you can ignore because this may possibly as routing loop on destination network anywhere, Sender is trying with less TTL count,
If you are looking a massive amount of traffic then it may an attack on your network. The purpose of this attack to make busy your router and get an unauthorized entry in your network.
https://www.cisco.com/c/en/us/about/security-center/ttl-expiry-attack.html
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
5 Replies 5
balaji.bandi
Can you pelase show us your configuration and give some example logs what show what kind if ICMP messaging going out, using what source IP and where destination ?
BB
x.x.x.30 is the c2921 router interface. The following log is from the next hop border router, the indication that something iwas amiss came from IDS monitoring, I applied this filtering  ACL  on the border router gateway interface to gain visibility...
I'm not sure at this point how the  the target IPs are being determined by the router
Mar 28 20:50:48.756 UTC: %FMANFP-6-IPACCESSLOGDP: SIP0: fman_fp_image: list sicmp filter denied icmp X.X.X..30 -> y.y.y.y  (11/0), 1 packet
Mar 28 20:50:51.237 UTC: %FMANFP-6-IPACCESSLOGDP: SIP0: fman_fp_image: list icmp filter  denied icmp 198.91.71.30 -> z.z.z.z (11/0), 1 packet
interface GigabitEthernetx/x
ip address x.x.x.30 255.255.255.192
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
ipv6 address xxxx:xxx:xxx:xxxxx::30/64
ipv6 enable
ipv6 nd ra suppress
no ipv6 redirects
no ipv6 unreachables
Hi, ICMP Type 11/Code 0 - is TTL exceeded - When using traceroute, each hop sends a TTL exceeded message upon TTL expiring, identifying each hop in the path.
HI,
Deepak Kumar
Deepak Kumar,
Thanks. I'll work on trying to figure out what might be causing the routing loops.
